Wich Intake mani???
Old Jul 26, 2007 | 03:37 PM
EFstyle's Avatar
Default Wich Intake mani???
what do you guys think i should do with my y7 (into a 91 Si with Si trans) keep the a6 ecu and harness and swap the a6 intake manifold onto the y7... seems like it would be WAY easier sensor wise... or keep my y8 intake mani on it and use my y7 ecu and harness?? anothing question...im going to buy oem motor mounts and then pick up Energy mount inserts, i know the 3 tranny ef tranny mounts will work for sure but what mount do i get for the driver side motor mount??
Old Jul 26, 2007 | 03:41 PM
racintweek2's Avatar
Default Re: Wich Intake mani??? (EKEJ6)
use the y8 mani,PM6 ecu and Si harness. you'll just have to extend the IAT sensor wires because the sensor is in the intake tube on the Y7 instead of on the mani like the A6
Old Jul 26, 2007 | 03:56 PM
EFstyle's Avatar
whats the PM6 from?? wouldnt using the Si mani and ecu be way easier?? wont i have to chage almost all the sensors??
Old Jul 26, 2007 | 04:08 PM
da6jdmteg's Avatar
Default Re: (EKEJ6)
just use your obd-0 stuff. your si ecu, manifold. etc. dizzy. you can use y8 manifold. but you probably run into some difficulties. like vacuum. and a few other sensors
Old Jul 26, 2007 | 04:14 PM
misha's Avatar
Default Re: (da6jdmteg)
pm6 is your si ecu
Old Jul 26, 2007 | 05:12 PM
EFstyle's Avatar
Default Re: (misha)
cool thanks guys
Old Jul 26, 2007 | 05:53 PM
Default Re: (EKEJ6)
i was assuming you had a y8 mani, and since it is a better mani why not use it.
Old Jul 26, 2007 | 06:35 PM
EFstyle's Avatar
Default Re: (racintweek2)
seems to me like it just makes it way easier...plus im not tryin to set the land speed record here...just tryin to get a daily driver together... i dought that the y8 is really that much better a6...
j-rome
12
Jul 28, 2008 08:27 AM
JohnnyB70
Aug 24, 2004 06:38 PM
BlackCRX
21
Oct 30, 2002 10:01 PM
Dano
Sep 11, 2002 06:44 AM
sicivic
Sep 2, 2002 10:14 AM
