can i use LS shafts on my J1 trans
Old Jul 26, 2007 | 03:17 PM
rewerbcrx's Avatar
Default can i use LS shafts on my J1 trans
can i use my 91 integra axles from my ls trans and put them on my j1 trans if i use the half shaft? or do i have to use a gsr half shaft and axles?
Old Jul 26, 2007 | 03:31 PM
racintweek2's Avatar
Default Re: can i use LS shafts on my J1 trans (rewerbcrx)
as long as the half shaft matches the trans you are using they are good to go.
Old Jul 26, 2007 | 06:50 PM
rewerbcrx's Avatar
Default Re: can i use LS shafts on my J1 trans (racintweek2)
so i can use the half shaft that matches the trans (93 gsr) .... and my LS axles? are the splines a different number?
Old Jul 26, 2007 | 11:39 PM
Rd91SiB18ls's Avatar
It will work just fine.
Old Jul 27, 2007 | 05:06 AM
rewerbcrx's Avatar
Default Re: can i use LS shafts on my J1 trans (Rd91SiB18ls)
others... please .... just trying to make sure
Old Jul 27, 2007 | 06:05 AM
4g hatch's Avatar
u can use the ls halfshaft and axles
tRex99
Nov 29, 2004 12:07 PM
Kevin Cliff
Jul 9, 2003 04:48 PM
vtec69
Oct 29, 2002 10:02 AM
pg_thao
Sep 15, 2002 11:38 AM
