Timing question on my build!
K so i got my b18c1 with ctr pistons in
i would TDC the cams and crank but when i pull up on the tensioner spring to tighten the belt and tighten the tensioner sscrew it would move the belt......
i am now 1 tooth off on the crank and my car feels like a b16 theres like lil to no pull
would being off a tooth do this?
Yes, I think so. High compression N/A motors are touchy like that, and my friend had timing troubles with his all-motor GSR for a while, which caused his motor to pale in comparison to what it used to be when the timing was correct.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludedriva »</TD></TR><TR><TD CLASS="quote">K so i got my b18c1 with ctr pistons in
would being off a tooth do this?</TD></TR></TABLE>
if everything is at TDC when the belt is put on then you are fine. it's when things move and the belt is not on is when there is a problem.
we didnt have the lower t cover on when we did this i used the mark on the oil pump to guide it
i just want to know why when i pulled up on the tensioner spring the belt and or crank would move as well throwing the timing off
we compensated for it by moving the crank a few teeth past tdc to make up for the movement
Haleiwa-Brando
Apr 14, 2006 11:17 AM
Ag3nt_Orang3
Jan 28, 2006 11:36 AM
