d16y8 ( help)
Old Jul 26, 2007 | 11:27 AM
1993civic's Avatar
Default d16y8 ( help)
i have a 93 honda civic with a d16y8 and all i have done to the motor is an intake and exhaust....what else can i do to it to make it faster? and where can i find the parts for cheap?
Old Jul 26, 2007 | 11:31 AM
95ProjectEJ1's Avatar
Default Re: d16y8 (1993civic)
I wouldnt waste anymore money on the motor unless it was a turbo, just my opinion.
http://www.turbod16.com
^^ Just my .02 ...
Old Jul 26, 2007 | 11:35 AM
polything's Avatar
do some search first mate.
turbo just like the other dude just said
Old Jul 26, 2007 | 12:42 PM
$nahk's Avatar
Default Re: d16y8 (polything)
Your best off swaping the motor for a b18, it will be cheap and more reliable than a turbo d16y8. Yeah it will not have as much power as the turboed d16 but you can always build the b18. Keep it all motor, I have had an bad experience with a turbo.
Old Jul 26, 2007 | 12:47 PM
philosofy1's Avatar
Default Re: d16y8 ($nahk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by $nahk &raquo;</TD></TR><TR><TD CLASS="quote">Your best off swaping the motor for a b18, it will be cheap and more reliable than a turbo d16y8. Yeah it will not have as much power as the turboed d16 but you can always build the b18. Keep it all motor, I have had an bad experience with a turbo.</TD></TR></TABLE>
what's best bet is what his wallet can spit out. why does he have to have a B18. there's nothing wrong with building a turbo d-series motor, especially if you are on a really tight budget.
and then there is the B16, cheaper than the B18, but more potential than the D16.
sorry if you had bad experiences with turbo's, but they can be quite reliable.
any motor put together poorly can give someone a bad experience, whether it's N/A or F/I.
Old Jul 26, 2007 | 01:02 PM
Default Re: d16y8 (philosofy1)
I think he may have been talking about the B18b1
But seriously... just turbo the D16y8, there is no point in spending extra money if you dont have to. If you do want to spend the extra money and do a swap, then a B18b1 would be a nice choice.
Old Jul 26, 2007 | 01:11 PM
97Ej6mike's Avatar
Boost is the best you will get out of your SOHC.
If your looking for more, look into a DOHC motor swap, most common being a B-series.
For more info, check out the FAQ section on the top 4 threads of this list under 92-00 civic/del sol.
Old Jul 26, 2007 | 01:19 PM
devney's Avatar
not much more you can do that'll be worth the money unless you go turbo or swap like everyone else said
Old Jul 26, 2007 | 01:23 PM
GsR92HaTcH's Avatar
from my past experience the money i spent to do the complete change over to a stock b series was enough to build my d for boost and buy a complete turbo set up thats just as reliable and much much faster...i went back to the d and happier then ever....
Old Jul 26, 2007 | 01:38 PM
venessEK's Avatar
i have a y8 and currently building it and boosting it
soo..BOOST!
Old Jul 26, 2007 | 05:12 PM
1993civic's Avatar
Default Re: d16y8 (nessEK)
what if i change the head to a f20 from a crv??? will that make it faster?
Old Jul 26, 2007 | 05:15 PM
gearhead16's Avatar
dont waist your time boosting that hunk of junk get a b series the d series always last lik 2 months on boost and blow a rod or main bearing
Old Jul 26, 2007 | 05:21 PM
Default Re: d16y8 (gearhead16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gearhead16 &raquo;</TD></TR><TR><TD CLASS="quote">dont waist your time boosting that hunk of junk get a b series the d series always last lik 2 months on boost and blow a rod or main bearing </TD></TR></TABLE>
^^ This is just about as great as the post below ... god damn
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civic &raquo;</TD></TR><TR><TD CLASS="quote">what if i change the head to a f20 from a crv??? will that make it faster?</TD></TR></TABLE>
Old Jul 26, 2007 | 05:36 PM
Imp-tuner's Avatar
From: Santa Ana ES in 415 NORCAL where clean ricers are found :P
If you don't want to expend money in swaps or turbo....try to buy some high performance pistons, camshafts and modified the transmission ....and lowered couple of mm to the engine block .....
Old Jul 26, 2007 | 05:39 PM
maynards_ek's Avatar
Default Re: d16y8 (Imp-tuner)
Wow...
Old Jul 26, 2007 | 05:41 PM
schardbody's Avatar
boost or spray
Old Jul 26, 2007 | 06:08 PM
1993civic's Avatar
Default Re: (schardbody)
if i'm going to get a swap should i get a b16 a b18 or a h22 if i'm just going to run all motor no turbo.
Old Jul 26, 2007 | 06:10 PM
jakedoza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt waste anymore money on the motor unless it was a turbo, just my opinion.
^^ Just my .02 ...</TD></TR></TABLE>
+10
ive seen 400+ WHP out of that engine... and that is my goal...
schardbody's Avatar
see sticky at top of forum titled "what swaps are available for my car" or get flamed.
Old Jul 26, 2007 | 06:27 PM
Default Re: (1993civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civic &raquo;</TD></TR><TR><TD CLASS="quote">if i'm going to get a swap should i get a b16 a b18 or a h22 if i'm just going to run all motor no turbo.</TD></TR></TABLE>
How much money are you looking to spend, and by spend I mean how much do you have right now or in the near future (year or less). And what kind of WHP goals are you looking for?
Old Jul 26, 2007 | 08:53 PM
1993civic's Avatar
Default Re: (95ProjectEJ1)
looking to spend bout 500-800
Old Jul 26, 2007 | 09:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1993civic &raquo;</TD></TR><TR><TD CLASS="quote">looking to spend bout 500-800</TD></TR></TABLE>
Just save it then and wait until that 500-800 turns into a few thousand.
Old Jul 26, 2007 | 09:43 PM
1993civic's Avatar
wait for what????
Old Jul 26, 2007 | 09:44 PM
Till you save more money for a swap or turbo... you are going to need a little more research and a little more than 800 to boost it properly even on a junkyard turbo.
Old Jul 27, 2007 | 04:38 AM
97Ej6mike's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 &raquo;</TD></TR><TR><TD CLASS="quote">Till you save more money for a swap or turbo... you are going to need a little more research and a little more than 800 to boost it properly even on a junkyard turbo. </TD></TR></TABLE>
You could find a used kit here on HT-marketplace for ~1500 or so (+/- few hundred). Someone i know used to come to meets with a boosted y7 EK hatch, and they paid around that much for a used Greddy kit.
