Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Disconnected my Batteries and Alarm doesn't Beep anymore :(
Old Jul 26, 2007 | 09:06 AM
pdd's Avatar
pdd
Default Disconnected and Reconnected my Car Battery and my AutoMate Alarm doesn't Beep anymore :(
So I disconnected the negative pole of my battery for installing an ipod and reconnected it again and my AutoMate alarm doesn't beep or panic at all anymore. The remote locks and unlocks the car but you don't hear any beeps anymore. Please Help!!! Thanks.
Modified by pdd at 10:23 AM 7/26/2007
Modified by pdd at 10:24 AM 7/26/2007
Old Jul 26, 2007 | 09:08 AM
awang's Avatar
Default Re: Disconnected my Batteries and Alarm doesn't Beep anymore :( (pdd)
i'm pretty sure one of your doors (or trunk) are not closed completely. check that first.
Old Jul 26, 2007 | 09:13 AM
pdd's Avatar
pdd
Checked and everything is closed and still not beeping
Old Jul 26, 2007 | 09:18 AM
pdd's Avatar
pdd
Also, in case that helps, when I was reconnecting the negative pole, the car alarm starting going off right away, off course, so I had the remote in my hand and pressed it several times while I reconnected the battery. Could that have disabled the alarm sound?
Old Jul 26, 2007 | 09:23 AM
pdd's Avatar
pdd
Sorry, is not a factory alarm is an AutoMate alarm. Also, I just read somewhere, I may have set the alarm to valet mode or passive mode or something without realizing it. Is this posible? and how do I fix it?
Btw, this is the remote that I have:
Old Jul 26, 2007 | 10:29 AM
fventura03's Avatar
maybe blew a fuse somewhere when you connected the negative back?
Old Jul 27, 2007 | 07:59 AM
punge's Avatar
Default Re: (pdd)
Do you not have a operators manual for the alarm system? If not, try checking the manufacturers site (if they have one) for troubleshooting.
Old Jul 28, 2007 | 09:50 AM
wrx-killer-Sti-eater's Avatar
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: (1em24me)
open the drivers door. Press lock, unlock, lock, unlock, lock. You should then hear the siren beep. You must of put it in valet mode by pushing the buttons to many times
cslegacy
Audio / Security / Video
Apr 20, 2008 06:47 AM
bmwracer316
Mar 7, 2007 11:14 AM
dukers
Jul 18, 2005 05:39 PM
stRtypR25
Jan 2, 2002 02:06 PM
