air condition problem
I have a 2001 Honda Civic LX. Last night I noticed a knocking in the motor area. It's not steady like a rod knocking but more of an off rhythm knock that comes and goes. When it is knocking I can get it to stop instantly by turning off the A/C What is causing this knock, and generally speaking what will the repair cost? Also, does this need to be repaired instantly or can I continue to use my A/C for a while without creating more damage resulting in greater cost? It still cools great. Thank You -William (from Carolina Beach NC)
Sounds like it could maybe be the pulley bearing on your A/C compressor, or the compressor itself - all you're doing when hitting the A/C switch is stopping the comp spinning. Sounds like that might be your problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LARS50 »</TD></TR><TR><TD CLASS="quote">HAVE THE AC SYSTEM CHECK FOR AIR IN SYSTEM MAY BE WHY YOUR GET NOISE IN AC </TD></TR></TABLE>
No need to yell.... check out your caps lock button (when the green light at the top right of your keyboard is lit that says "Caps Lock"... that means it's on)
I like EM2_UK's response I don't know for sure either but sounds good lol
