Problem with swap...HELP..
Old Jun 10, 2002 | 01:38 PM
Griffins_Importuning's Avatar
Default Problem with swap...HELP..
I just swapped in a b16 engine. It seems to idle fine but i have a problem. The engine seems to be running really hot, even though the engine temp guage is not at half way yet. I let it run for 20 min or so. and the fans did not kick in. I am using the factory crx hf fans and radiator. I disconnected the air conditionar but dont think that would have anything to do with it. I have one white plug that is for the radiator fans . there is no where to clip it in on the new harness. It is there on the factory b16 harness though. I am really confused. What should i do. Please help...
Old Jun 10, 2002 | 02:52 PM
90SIhybrid's Avatar
Default Re: Problem with swap...HELP.. (Griffins_Importuning)
i also just finished and having the same problem i have a brand new thermostat also i can feel the thermostat kick in but the fan doesn't come on either. if anyone can help or has had this same problem help would be appreciated
Old Jun 10, 2002 | 03:49 PM
-=TWITCH=-'s Avatar
Default Re: Problem with swap...HELP.. (90SIhybrid)
I have the same prob my car dosnt run hat at all but I have never herd/saw my fan run I have a DOHC ZC
Old Jun 10, 2002 | 07:04 PM
i have read on other posts that you can relay a switch to the fan connection so you can manually turn on the fans., if this is possible how will it be done. i am missing a plug somewhere for one of my fan belt...have no idea what happend....fans still wont run and im throwing code 22. its 2 long blinks and two short blinks...
Old Jun 10, 2002 | 07:59 PM
velocitysir's Avatar
alright, with my old crx which had a zc, the operating temp on that was like the needle half way up.... the fans should kick on, if they don't run a radio shack toggle switch to your dash, or replace your radiator fan switch.... just let it run, if the needle goes past way half then there's prolly somthing wrong........
Old Jun 10, 2002 | 08:24 PM
Default Re: Problem with swap...HELP.. (velocitysir)
where is the raditor fan switch....connected to the fan. or is it need the therm.
Old Jun 10, 2002 | 08:51 PM
sweeet. i just connected wires to the relay switch and the fans turnied on. aight time to get a togglle. thanks
Old Jun 10, 2002 | 09:18 PM
r7's Avatar
r7
i've never had the fan turn on yet either.. i think the fan motor is done... is there an FAL fan for the ef ?
riceforlife
14
Nov 29, 2007 06:46 PM
Roster99
Jun 7, 2005 12:40 PM
PhazedSI
Apr 27, 2004 03:58 PM
rickytz7111
Feb 25, 2004 06:30 AM
brandCRX
Feb 19, 2002 10:49 AM
