AC prob.
Old Jul 26, 2007 | 05:07 AM
tlovaj's Avatar
Default AC prob.
So I just want to confirm everything. I was recharging my a/c and got a little careless and put too much in, to the point where it started sparying out. Now when I use my a/c there basically is no a/c. It runs and then i get this "clunk" noise everytime it tries to kick in. And after its been doing that for a while, it starts spitting out freeon. I know its my a/c compressor but I was hoping there would be a cheaper way to fix rather than dishin out $300 for it. What do you guys say?
Old Jul 26, 2007 | 06:46 AM
Honda_Accord's Avatar
Default Re: AC prob. (tlovaj)
when you OVER charge the a/c does not work. Mabey try to let some out and see if u still get that clunk noise, if so then go to a junkyard, pick a pull or something to find a new compressor
Old Jul 26, 2007 | 12:09 PM
zsudz922's Avatar
Default Re: AC prob. (Honda_Accord)
if you over charged the system and tried using the a/c you probably destroyed/damaged the compressor.try letting some out by using a screw drive and pressing the valve down on the H caped valve(not the one you used to recharge the system,the opposite of the one used to recharge).let it out with the a/c off.after you let a descent bit out turn on the a/c and see if if makes the noise.if it still does you need to let out more and if it doesnt then your good.
hopefully you did not damage/kill the compressor.
Old Jul 26, 2007 | 07:50 PM
hondadude's Avatar
there is a high pressure "pop off" on the back of the compressor.
Is that where it sprayed out?
The relief valve doesn't reset and has to be replaced, but it is a lot less $$$ than a compressor.
Old Aug 13, 2007 | 12:20 PM
trujillov's Avatar
Default Re: AC prob. (hondadude)
My ac compresser on my 2003 accord makes clunk noise when started but works fine and after being turned on it will not make the noise again until it sits for a prolonged time. any ideas?
DeeJaayM
Honda Civic (2006 - 2015)
Jul 16, 2018 08:16 PM
EM2junkIE
Honda Civic (2001 - 2005)
Jun 18, 2008 04:36 PM
vishyncsu
Jun 3, 2004 04:10 PM
PnX-R
Jun 8, 2002 06:36 PM
