1950 Chrysler with a Duramax swap
Hey guys! Well my brother and his friend are putting a duramax engine in a 1950's chrysler and i thought id share the progress thus far. So here are the pics he has from his cell phone and i will update as more gets done. The motor setup is a LB7 with a 6 speed allison transmission. Going to most likely have a single 5'' side pipe with a kick out at the end.
Before when they started
Chopping the roof
Chopped
Motor out
Motor being mocked up
and inside the car
Il have pics tommorow of the motor mounts all done and the transmission brace all done. Let me know what you guys think!
UPDATE*******
Makin the exhaust!
newest pics
updated pics, the shop building the car is called Bloody Knuckles Chop Shop in SLC, my brother and his friend own it. more of there work at http://www.bloodyknucklesslc.com/
Modified by stockredej1 at 5:22 PM 12/11/2007
Modified by stockredej1 at 8:05 PM 4/5/2008
Chopping the roof
Chopped
Motor out
and inside the car
UPDATE*******
Makin the exhaust!
newest pics
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GTiR NX »</TD></TR><TR><TD CLASS="quote">but is that chassis going to put up with that kind of torque, arn't those engines about 600 ftlbs ? lol </TD></TR></TABLE>
some of them go over 1000 ftlbs tq.
it all depends on what model he go that duramax from. the 1500,2500 or 3500.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fo-Do Fanatic »</TD></TR><TR><TD CLASS="quote">
it all depends on what model he go that duramax from. the 1500,2500 or 3500.</TD></TR></TABLE>
ummm, no.
1st off, 1500's dont have duramax's
2nd, the Duramax is the exact same engine in 2500's/3500's/large trucks, which makes 600ish ft/lbs
it all depends on what model he go that duramax from. the 1500,2500 or 3500.</TD></TR></TABLE>ummm, no.
dont ask me why I know this...
but there are two engines that came in them the LB7 and one other...LB9??? I don't recall what it was called. But there are two different engines.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Rok »</TD></TR><TR><TD CLASS="quote">its still the same basic engine.</TD></TR></TABLE>
i was under the impression the fueling setup is quite a bit different betweem the two.
as well as the oil setup.
ummm, no.
2nd, the Duramax is the exact same engine in 2500's/3500's/large trucks, which makes 600ish ft/lbs</TD></TR></TABLE>
i believe theres a ford with almost or over 1000 ftlbs. dont quote me though.
ummm, no.
Well i stopped by the shop today with a real camera to get some pics for you guys. Here they are!
Car again
New rear suspension being installed now
And now some motor pics and of the tranny mount.
Car again
i believe theres a ford with almost or over 1000 ftlbs. dont quote me though. </TD></TR></TABLE>
you are probably thinking of a F-650 or something with a CAT motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ebydrc »</TD></TR><TR><TD CLASS="quote">duramax > chuck norris
cummins < paris hilton</TD></TR></TABLE>
apparently you are retarded.
