Mugen Exhaust & JDM ITR Header Installed Today
Old Jul 25, 2007 | 05:19 PM
THE ONE's Avatar
Default Mugen Exhaust & JDM ITR Header Installed Today
Had these installed today with a test pipe as well and the car feels great. I am surprised I can actually feel a difference with the new parts added. Next week the car goes in for the piston rings. I decided to go ahead and throw in some CTR pistons while it's apart too for a little extra power, while still being a 100% reliable daily driver. Only things I will add now is changing the intake to an AEM cold air, and running a JDM ITR ECU to ditch the CEL and run better with the new pistons. After that I'm done with the car and will run it that way for as long as I own it.
Old Jul 25, 2007 | 06:51 PM
t-town_ep's Avatar
good plan!
Old Jul 25, 2007 | 07:07 PM
Casey's Avatar
Default Re: (t-town_ep)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t-town_ep &raquo;</TD></TR><TR><TD CLASS="quote">good plan! </TD></TR></TABLE>
not exactly. pct pistons are not very well designed, are heavy, and the cr will be in the upper 12's. get jdm b16 pistons instead
Old Jul 25, 2007 | 07:19 PM
JjuuN R's Avatar
No pics...
Old Jul 25, 2007 | 11:14 PM
DC2R_JOE's Avatar
Default Re: (JjuuN R)
put some pics up
Old Jul 26, 2007 | 05:49 AM
Mr.OB*GYN_Rhett's Avatar
Default Re: (DC2R_JOE)
yeah what Casey said, too much for AZ man. Import Powerhouse/RS machine built me an lsvtec with pr3 pistons, yielded around 11.5-.7:1 and that **** didn't last 5 months on a stock ecu. If you can even run that high of CR here in the summer I highly recommend that you invest in some good tuning. Also, screw AEM, get a BPI velocity stack
Old Jul 26, 2007 | 05:51 AM
mtny's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R &raquo;</TD></TR><TR><TD CLASS="quote">No pics... </TD></TR></TABLE>
Old Jul 26, 2007 | 05:52 AM
itr1244's Avatar
Default Re: Mugen Exhaust & JDM ITR Header Installed Today (THE ONE)
umm i dont think jdm header will adopt your snail that good
Old Jul 26, 2007 | 02:22 PM
JackBurton's Avatar
Old Jul 26, 2007 | 03:30 PM
Mrs TheOne's Avatar
NNOOOO!! No more suggestions. LOL
His car has enough parts on it. Time for him to mod mine!!!
Old Jul 26, 2007 | 04:27 PM
THE ONE's Avatar
Default Re: (Mrs TheOne)
I will take pics when I can. I guess I will just leave it stock then. We plugged in the CR on a site and it said it would come out to 11.75:1
Old Jul 26, 2007 | 04:38 PM
Comp97GSR's Avatar
Default Re: (THE ONE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THE ONE &raquo;</TD></TR><TR><TD CLASS="quote">I will take pics when I can. I guess I will just leave it stock then. We plugged in the CR on a site and it said it would come out to 11.75:1</TD></TR></TABLE>
Mr. The One, that is inaccurate. It will be 12+.
May I suggest JDM ITR pistons. 11.1 CR should be a great compromise between power and reliablilty.... on a stock ECU.
Old Jul 26, 2007 | 05:01 PM
THE ONE's Avatar
Default Re: (Comp97GSR)
I'm getting all my data from c-speedracing.com. They have a CR calculator and here is the link to the results with my car if the link works.
http://www.c-speedracing.com/h...c.php
THE ONE's Avatar
Well the link gets you to the calculator anyway and you can plug in the details. I will still be using an OEM headgasket. Please advise!
Old Jul 26, 2007 | 05:11 PM
it looks to be at least 12.1:1 idk though, i only took alot of time to check out lsvtecs awhile back. gotta figure youll be milling the head as well...
Old Jul 26, 2007 | 05:58 PM
THE ONE's Avatar
Default Re: (Mr.OB*GYN_Rhett)
No, just resurfacing it.
Old Jul 26, 2007 | 06:02 PM
THE ONE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Comp97GSR &raquo;</TD></TR><TR><TD CLASS="quote">
May I suggest JDM ITR pistons. 11.1 CR should be a great compromise between power and reliablilty.... on a stock ECU.</TD></TR></TABLE>
And this is why I think the CR calculator is accurate. If you plug in JDM ITR pistons it says 11.1:1. Check it out with the JDM CTR's, it comes to 11.7 and change.
Old Jul 26, 2007 | 06:06 PM
Casey's Avatar
And this is why I think the CR calculator is accurate. If you plug in JDM ITR pistons it says 11.1:1. Check it out with the JDM CTR's, it comes to 11.7 and change.</TD></TR></TABLE>
its not. theres a huge thread in the all motor section from a long time ago. that calculator is not accurate. go ahead and put them in. i know internet sites is better that real world experience. not that ive ever had pct pistons in a c5 with a mugen head gasket tuned with an afc or anything
Old Jul 26, 2007 | 06:41 PM
Comp97GSR's Avatar
Default Re: (Casey)
It is your car so do what you want. The C-Speed online calculator is not accurate.
IMO PCT's in 1.8L's are the worst piston you can run. I feel they make too much compression for a cast piston. If you can find them, P30's could make the same power, if not more. Plus they are lighter than the R series pistons.
Old Jul 26, 2007 | 06:50 PM
Comp97GSR's Avatar
btw, I got 12.09 using the C-Speed calculator. You must be using the B18C piston-to-deck height. You should use the B16B. The CR will in reality be about 12.8.
Old Jul 27, 2007 | 05:43 AM
THE ONE's Avatar
Interesting. Thanks guys, I think I will just leave the stock ones in or use JDM ITR's. I just want a little more go while everything is apart, while still maintaining FULL daily driver reliability.
jerzey908
Dec 29, 2009 04:27 PM
anothersickhatch
Jul 9, 2009 09:30 PM
Austin
Aug 16, 2005 06:46 AM
iv
Jan 17, 2005 12:39 PM
TeamDOHCside
Dec 6, 2003 07:27 PM
