NO speakers/ wires in doors
Old Jul 25, 2007 | 04:20 PM
neb11ihtut's Avatar
Default NO speakers/ wires in doors
hey hows it goin guys
heres my problem
i have a k20a swap in my EG and i also did a dash swap ( harness was all hacked up in the dash i got )
the shell was fully gutted when i bought it
so there are no speakers in the doors or any wires
do i go to the back from the back of the fuse box and find the wires that corespond to each speaker and then just run those to the speakers?
how do i go about putting them in?
im very confused
any help would be greatly appreciated
Thanks , Ben
Old Jul 25, 2007 | 04:38 PM
fcm's Avatar
fcm
Old Fart
Default Re: NO speakers/ wires in doors (neb11ihtut)
The dash harness should have the door harness A piller plugs on it, and you will need door harnesses, that plug into the A piller plugs. 94
Old Jul 25, 2007 | 04:50 PM
neb11ihtut's Avatar
Default Re: NO speakers/ wires in doors (fcm)
i dont have a door harness what does it look like?
and where does it connect to on the dash harness?
Old Jul 25, 2007 | 05:01 PM
neb11ihtut's Avatar
could i possibley just run the wires straight from the head unit to the speakers
and run power straight from the battery for the head unit?
Old Jul 25, 2007 | 05:39 PM
B18C_EJ8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neb11ihtut &raquo;</TD></TR><TR><TD CLASS="quote">
do i go to the back from the back of the fuse box and find the wires that corespond to each speaker and then just run those to the speakers?</TD></TR></TABLE>
There are no speaker wires going into the fuse box. Ever.
If you don't have the correct harness for the radio/speakers, then yes, you can just run wires into the door. Use the existing holes/boots if possible.
Old Jul 26, 2007 | 06:37 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by neb11ihtut &raquo;</TD></TR><TR><TD CLASS="quote">i dont have a door harness what does it look like?
and where does it connect to on the dash harness?</TD></TR></TABLE> Depend on the doors they are for, in a base model it will be short and have the 2 speaker leads and a multi-pin plug, if they are for a "full load" car the harness is much bigger containing speaker, power window and power door lock wiring, will still use the same multi-pin plug.
The dash harness plugs that the door harnesses plug into should be part of the dash harness, as will the stock radio harness plug, the dash harness plugs and the door harness plugs plug into each other and "clip" into the holes in the A pliers.
B18C_EJ8 is correct, you could just run speaker wires into the doors, both powers, switched and constant power, can be found at the free pins on the under dash fuse box. 94
Old Jul 26, 2007 | 04:48 PM
neb11ihtut's Avatar
word thanks alot guys
im definetly not seeing any clips
so it looks like i will be doing it that way
thanks for your help
Old Jul 27, 2007 | 07:44 PM
jz98ctr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">
If you don't have the correct harness for the radio/speakers, then yes, you can just run wires into the door. Use the existing holes/boots if possible.</TD></TR></TABLE>
word you can always run new wiring which usually ends up being better than the thin stock wiring that comes with the vehicle anyways. any power leads you run (ex. constant power and/or switched ignition)...make sure to fuse the line!
Sp00nFed EM1
Sep 8, 2015 03:09 AM
Jonknee
11
May 27, 2014 12:14 PM
goldsy
Honda CR-V & Element
Jan 5, 2014 11:33 AM
Chriser0
Mar 21, 2013 07:07 PM
willsmysticcobra
Jun 30, 2008 06:41 PM
