Sedan Seats in a Hatchback
Old Jun 10, 2002 | 11:57 AM
OldSchoolHatch's Avatar
Default Sedan Seats in a Hatchback
I saw a DX sedan at the junkyard the other day in good shape. But it wasn't like any 4th gen civic I've seen. The stock cloth seats were a little nicer than other DX ones I've seen. The whole seatbelt assembly was different and most was connected to the seats. The lower belt and the one that goes across were seperate. Also the side molding looked different, and the front part of the hood where the front emblem is was shorter with a black plastic piece going across there. Is this stuff normal, because I'm not used to seing sedans. Anyway I want to use these seats, so will they fit the hatchback? And how much of a pain is it to swap seats?
Old Jun 11, 2002 | 12:10 PM
Default Re: Sedan Seats in a Hatchback (OldSchoolHatch)
I'm also thinking of swapping seats from a 96 integra, but they're not a direct fit I don't think. Can anyone tell me how hard it is to swap 4g civic sedan seats or the integra ones into a hatchback?
[Modified by OldSchoolHatch, 9:11 PM 6/11/2002]
Old Jun 11, 2002 | 12:11 PM
Hcivic88's Avatar
u cant put sedan seats into a hatch. for one, they dont flip forward so you would not have access into the back seat area
Old Jun 11, 2002 | 12:13 PM
Urban Business
Guest
Posts: n/a
Default Re: Sedan Seats in a Hatchback (Hcivic88)
i have 93 accord seats in mine. had to flip passengers w/ drivers, that way 3 of 4 mount mounts were sort of stock. has to drill new hole for 4th mounting point.
Old Jun 11, 2002 | 03:16 PM
Ham'ed Hatch
Guest
Posts: n/a
Default Re: Sedan Seats in a Hatchback (TorteX)
just curious...what made you go with accord seats?
Old Jun 13, 2002 | 10:09 AM
These seats do push forward. I don't think they originally came in this car since they're nicer than DX seats too. So does anyone know how to go about changing these?
Old Jun 14, 2002 | 11:01 PM
Doesn't anyone know about changing seats in a hatchback?
Old Jun 14, 2002 | 11:53 PM
Trinity's Avatar
yeah its called bolts , you take a ratchet and a socket and take them out. the fronts are usually held down by 4 bolts 2 in the front and 2 in the rear.
Old Jun 15, 2002 | 12:04 AM
FredoTheChimp's Avatar
Default Re: Sedan Seats in a Hatchback (two.oh)
accord seats are so nice and big i miss my accord, A/C, PS, PL, PW, ahhh all the luxaries
Old Jun 15, 2002 | 12:49 AM
Default Re: Sedan Seats in a Hatchback (Accord92sir)
okay thanks. Do you know how it would be swappin the 96 integra seats?
Old Jun 15, 2002 | 04:42 AM
Trinity's Avatar
you would have to make custom brackets. that stuf isn't gonna just drop right in
Old Jun 15, 2002 | 11:06 AM
si91's Avatar
Default Re: Sedan Seats in a Hatchback (Trinity)
easy thing to do
just take off the bottom glider/slider that holds that seat to the body and swap it out with the bracket from your car 4 bolts that go into the chair itself easy thing to do i did that with my 97 gsr seats into my 91 hatch...
Old Jun 15, 2002 | 11:11 AM
So all I have to do is swap the seats with the slider brackets and I won't have to worry about custom brackets or anything? Do the holes for the slider things match up or do I need to make new holes in the floor?
ZC_powered_4dr.
Sep 1, 2005 05:19 PM
EeeJayEight
Aug 21, 2004 12:00 PM
foz
Jan 15, 2004 05:53 PM
kyler
May 27, 2002 02:22 PM
