Bending thin wall chromoly
I have a JD2 #3 bender, bending 1" 0.065 4130 on a 3" radius, and every other bend flattens out on a 90* bend. it starts to flatten out at about 80*
I'm assuming its simply due to the density of the material & the fact that it is so thin, there is no room for it to stretch so much on a 3" radius 90* bend.
Am i correct in thinking this?
I am not a newbie to this, just saying i know how to use the bender.
Thanks guys
Thanks guys
I use a hossfeld bender and can bend around a 2 1/2 radius die usually. Do you use oil on the dies. You should oil the follow die which is the one that does the bending. That will put less stress on the outer radius material while bending.
Also make sure that the tubing doesn't slip in the clamping . If it slips it will also tend to kink or flatten
the bender you have works the same and is basically a copy of the hossfeld
vtec25
Sep 3, 2006 11:10 AM
