LS throttle body on ZC manifold?
Old Jul 25, 2007 | 07:50 AM
I8ayellowcrayon's Avatar
Default LS throttle body on ZC manifold?
I did a search, and the best I can find is that 92-00 B series, D series and H series TBs are all interchangable.
My deal is, I have a DOHC ZC, so I can't put a 92+ manifold on it. The ZC TB is the same as the D16A6. I have a 90 LS TB, and I was just wondering if the 90 LS TB and the D16A6 TBs are interchangable? I'm not sure where the pre 92 TBs fall as far as swapping around.
Thanks!
Jason
Modified by I8ayellowcrayon at 9:21 AM 7/25/2007
Old Jul 25, 2007 | 08:24 AM
jlicrx's Avatar
Default Re: LS throttle body on ZC manifold? (I8ayellowcrayon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I8ayellowcrayon &raquo;</TD></TR><TR><TD CLASS="quote"> I have a 90 LS TB, and I was just wondering if the 90 LS TB and the D16A6 TBs are interchangable?</TD></TR></TABLE>they are not - maybe you could find an OBD1 DOHC ZC intake manifold?
Old Jul 25, 2007 | 11:34 AM
Maybe... I haven't been able to find any OBD1 ZC parts other than motors/swaps... I'll look around some more though.
Thanks for the info though I oughtta just PM you every time I have a ZC question from now on lol.
Old Jul 26, 2007 | 10:58 AM
94b16teg's Avatar
Default Re: (I8ayellowcrayon)
I just used a ls throttle body on my mini me. It would not fit the stock a6 manifold so i put what i think is a 92-95 civic si manifold on it and it bolted right up. The only other thing i had to change was the part where the throttle cable hooks up you need to use your stock one. I took a few hours to figure out which parts to use but now it works great. Goodluck!
Old Jul 26, 2007 | 11:02 AM
jlicrx's Avatar
Default Re: (94b16teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94b16teg &raquo;</TD></TR><TR><TD CLASS="quote">I just used a ls throttle body on my mini me. It would not fit the stock a6 manifold so i put what i think is a 92-95 civic si manifold on it and it bolted right up. The only other thing i had to change was the part where the throttle cable hooks up you need to use your stock one. I took a few hours to figure out which parts to use but now it works great. Goodluck!</TD></TR></TABLE>unfortunately, the SOHC intake manifold will not bolt onto the DOHC ZC head
Old Jul 26, 2007 | 11:37 AM
STREETWERKZ's Avatar
Default Re: (jlicrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jlicrx &raquo;</TD></TR><TR><TD CLASS="quote">unfortunately, the SOHC intake manifold will not bolt onto the DOHC ZC head</TD></TR></TABLE>
http://www.zcspeed.com/adapterpage.htm
you have the link in your sig.
Old Jul 26, 2007 | 01:50 PM
Dang. Are you still making those??
jdm_jeners
Apr 26, 2007 09:00 PM
janz3n
Mar 29, 2007 04:39 PM
JDM_COUPE94
Mar 19, 2007 07:13 PM
Autoworks
10
Feb 8, 2006 02:39 PM
94blackhatch
Jan 15, 2004 10:31 AM
