Completion of my swap....
Ok heres the stuff i have for my swap siting in my garage, I remvoed the axles already... and 1 mounting point is out on the old b16.
Stuff I have:
HASPORT billet mounts
92 DA b16a1
y1 tranny
HASPORT si to sir harness
HASPORT linkage
new stock clutch
I was wondering tell me the stuff i should replace on motor, and I know many b series parts are interchangable, but could you guys tell me which car i should get each part from, also i was wondering of anybody had pictures of where they hit inside the engine bay to provide clearence, i was reading my instructions, but iim beginning to get confused. thanks
Stuff I have:
92 DA b16a1
y1 tranny
HASPORT linkage
new stock clutch
here is some of the small parts you will need.....dont know if you have seen it or not but here ya go..... http://www.hasport.com/88-91_OBD_B-series_Swap_Tech.htm
hit the wall under the master cylinder where the alternator will sit.......90-91integ cap and rotor.....94del sol vtec motor parts (timing belt, water pump)..some stuff off the top of my head
first test fit the rear mounting bracket to the mount and let it sit.. See where the bracket hits the rear cross member?? bend that area down.. if you dont, when you turn your motor on after the swap, you will hear a rattling/ vibrating sound.. that's the mount against the cross member..
we are talking about the front crossmember correct?!! do not bend the subframe under the firewall!! it is true about the driver's side needing some denting, and it does need a good deal of denting. as for the front crossmember, cut off the stock mount, and you will have to trim into the middle towards the motor if you are running an aftermarket header. B series parts are B series parts. use the 99-00 SI parts whenever possible, as well as del sol VTEC parts. i would strongly reccomend a new head gasket, timing belt and water pump. do it now while it is easy to get at the side of the motor before dropping it in!
Eric
you need...
90-91 non obd distributor, injector plugs. 90-93 rear engine mount. 91 integra upper and lower radiator hoses, 90-91 clutch and throttle cables.
And you do have to hammer down the crossmember to fit a JDM header. I'm using the new billet mounts and the only diffference is its about 1/4 inch taller, better alignment of axles.
Hasport mounts you do not need to dent the front crossmember at all. You may need to dent the rear one but first fit the mounts on ant the engine rear bracket and see if you have enough room.
I'm pretty sure Hasports new mounts dont need the rear member dented at all. But to be safe check it first
You don't need to hammer down the crossmember if you're putting a header other than a JDM 4-1. The rear lip by the firewall need to be folded to avoid vibration...hasport site shows all photos and instructions.
hondatuner020
Nov 30, 2006 09:28 AM
eg6hatch
May 3, 2005 02:37 PM
