how do i get rid of maint req'd light and airbag light?
i have an 04 si and i put my buddies type r gauge cluster in, my maint req'd light and airbag/srs light came on, how do i get rid of these? i have k-pro so i dont know if i can take out that plug and reset my ecu
To fix the maint req'd light, Press and hold the button on your cluster. Now turn the key over, but dont start. Just keep pressing the button untill the light is out. Now let off the button and turn the ignition off. Then start the car, It should be fixed.
there's a paperclip trick to the SRS thing. unplug the SRS plug, its the yellow one inside the interior fuse box. take a paperclip, stick one end into one terminal, one into the other. turn the key to position II, SRS light should go off. take out paperclip, it'll turn back on. put it back in, it'll turn off, stay off, flash twice or so, then stay completely off. remove paperclip, take out key, and put the SRS plug back. then you're finished
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms »</TD></TR><TR><TD CLASS="quote">there's a paperclip trick to the SRS thing. unplug the SRS plug, its the yellow one inside the interior fuse box. take a paperclip, stick one end into one terminal, one into the other. turn the key to position II, SRS light should go off. take out paperclip, it'll turn back on. put it back in, it'll turn off, stay off, flash twice or so, then stay completely off. remove paperclip, take out key, and put the SRS plug back. then you're finished</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice »</TD></TR><TR><TD CLASS="quote">Does that reset the SRS system or just turn the light off? (Will the airbag work?)</TD></TR></TABLE>
i had my srs light go on and i did that paper clip trick and it didn't work so when i was at work i just hooked up my car to the scan tool at work and reseted my srs light in like less then 1 min....
DumpedSi
Sep 11, 2003 08:42 PM
