d16 vtec solenoid wiring
My friend just got a vtec ecu. The solenoid is in the car but there is just a green wire. I read that you need to connect the wire to pin out A8 but that's where I'm lost. Is this pin out in the ecu ? or in the fuse box. I'm confused because I also read that you should connect the wire to positive pole of the battery.
Thanks
Thanks
lsvtecSIrex
Jun 14, 2006 03:13 PM
ilovemyb16a
May 18, 2006 12:58 PM
