A/C compressor always engaged and cooling fans always run!
Old Jul 24, 2007 | 03:45 PM
nicholi185's Avatar
Default A/C compressor always engaged and cooling fans always run!
I just purchaced a 95 honda accord lx. to the excitement of getting the car home to learn more about it I find that I cannot turn the A/C compressor of by dash switch or fan speed selection dial while the engine is running. also the engine cooling fans both together run continuously from the time I turn the key on until its turned off. I purchaced a haynes manual which doesnt contain the schematic for the cooling fan circuit, but did have a few simple diagnostics for the circuit. one of them was to check the wireing to a control box located behind the glove box, following this procedure everything tests ok, but I did find a 3-point conector with a pig tail to ground and by disconnecting this wire both A/C compressor and cooling fans turn off now the switch on dash pannel still has no effect and the temp switches are not responding. anyone have the diagram or a clue?
Old Jul 24, 2007 | 04:31 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: A/C compressor always engaged and cooling fans always run! (nicholi185)
There may be a short, check the Red/Blu wire between the compressor clutch relay and the ECM. Also check any wire harnesses near brackets for pinched or cuts.
Old Jul 25, 2007 | 10:14 AM
sonicxtacy02's Avatar
Default Re: A/C compressor always engaged and cooling fans always run! (tech8)
the problem could also be the clutch is stuck.
rhinoceros777
Jul 24, 2016 06:10 PM
1534william
Jul 18, 2012 12:55 PM
Frozen E
85
Apr 4, 2012 02:24 AM
jdmturboitr
Jul 23, 2009 08:08 PM
dingusjt
Jul 15, 2002 10:40 AM
