Power Steering Removal Kit Placement...
Well I finally decided to get rid of all the power steering junk under my hood and car, and found a really nice spot to mount the reservoir/breather for the kit. Kit was purchased from user Padawan if I remember correctly and came with all the correct Aeroquip fittings.
Car feels really good with the kit... You can see in the 2nd picture the Tilton reservoir/breather kind of lines up with the other Clutch MS and Brake MS...
I drove it just with the belt removed for a year, it feels a lot nice with everything removed and the kit added...
It feels kind of in between what it felt like with the Power Steering on and functional and with the belt only off.
Without the negative resistance of the PS of course...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seedc2 »</TD></TR><TR><TD CLASS="quote">i think it was about 65-70 bux</TD></TR></TABLE>
Something close to that IIRC.
But the kit is COMPLETE!!!
I removed my whole rack, lines and pump. Installed a manual rack from a Del Sol and have never regreted it. Just remember to modify the "C" clamp that holds the rack in place.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2R »</TD></TR><TR><TD CLASS="quote">man, there is dust all over that show car's engine bay. clean that ****!
Yeah yeah, funny thing it's faster then your SCed R all motor.
</TD></TR></TABLE>Yeah yeah, funny thing it's faster then your SCed R all motor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R »</TD></TR><TR><TD CLASS="quote">
That's only because his is always broken.
</TD></TR></TABLE>That's only because his is always broken.
I did the same delete on the track car...using Realtime's setup, which is basically what Padawan sells. Works really good. I ran out of tubing so I ended up mounting it on the inboard side of the tower (hidden by the ITR front bar)
I put a manual rack w/ sub-frame and changed mines over, than using the p/s rack w/ a resovior.And using the maual sub-frame, you dont have to worry about modifying the c clamp. But you did a good job tho.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J.Berta »</TD></TR><TR><TD CLASS="quote">I put a manual rack w/ sub-frame and changed mines over, than using the p/s rack w/ a resovior.And using the maual sub-frame, you dont have to worry about modifying the c clamp. But you did a good job tho.
</TD></TR></TABLE>The guy who modified my clamp was once going to build a tubular subframe that would be very strong but lighter. Maybe one day he'll get back around to it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JjuuN R »</TD></TR><TR><TD CLASS="quote">Hell I want to see that...</TD></TR></TABLE>When I get around to it I'll give him a shout and see if he's given it anymore thought. If anyone can figure how to do it (correctly), he can!
JDubya
Oct 22, 2003 06:44 PM
