wilwood or brembo
why brembo, and not willwood everyone? will brembo stop your car faster? cosmetic? what is the dealio....please give some insight. Thanks. I am rolling 18" wheels and thinking about big brake kit down the line.
Is it me or has there been an influx of the bling blingers on the board lately? Everyone's rolling on 18s/19s y0! Anyway..
18s will actually make it HARDER to slow down, since you have more rotational mass to stop. More weight means more braking effort.
Honestly, I wouldn't do either. You just need good pads, tires, and Brembo OE rotors. If I had to choose, probably Brembo.
I don't plan on that upgrade until I get my car running and tracking.
Now whether or not everybody needs to...
doesn't wilwood make a lightweight kit for less rotating mass....
My buddy's 91 CRX has the wilwood kit up front. There is nothing I can do with stock calipers to make it stop like his.
These people I speak of are the ones that are the road racers, most of them compete in Honda-Challenge. Ultimately, your tires decide how fast you stop, before you start sliding. As I said, if you want to stop faster, all you need are good tires, pads, and the Brembo OE rotors. If you plan on autocross or track events, switch the fluid to a better fluid. A lot of people use ATE super blue or gold (same stuff, different color).
since the calipers don't actually spin, it doesn't add to rotational mass. it is unsprung mass however and would affect how your springs/shocks behave.
I don't think there is a single person in the Autocross/Road race forum that has upgraded their calipers or put bigger rotors on their cars. I bet if you ask any of them, they will say "If you can lock your brakes, then your calipers are fine."
but it doesn't mean more powerful calipers, and larger rotors will not stop the car better. A CRX HF's brakes are capable of locking up the wheels on an ITR, but it doesn't mean they'll clamp faster and harder, disappate heat better, and do a better job of resisting fade.
I'm not argueing with ya though. I'd bet 99% of the folks here, me included, don't require such extreme braking.
Absolutely correct...
I don't agree with the cross drilled and/or slotted rotors that come with these set-ups though.
[Modified by G2LSS, 10:37 PM 7/8/2002]
