any idea how to piant a hood like a carbon fiber style?
the topic say everything... i hear that some ppl did it. i j/w how u paint a hood so it look like a carbon fiber hood?
Very carefully. I think that would be a pretty tedious job. I mean you could paint it in tiny checkers and it may look like a carbon fiber from a distance, but up close it would look like the dookie.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MurdersV8s »</TD></TR><TR><TD CLASS="quote">don't waste your time, you can't fake the funk</TD></TR></TABLE>
This is true, it'll probably cost just as much or more than a real carbon fiber hood to get your hood painted to look like carbon fiber, may as well just buy one.
use the fiber dry wall tape it has little squares in it and is self adhesive..do a black base then apply the tape and go over with the gray coat...i've seen some cool effects done with the just make sure you use light coats so it wont bleed
Personally I would stick with the real deal, but if you are set on doing this... I hope this helps. http://youtube.com/watch?v=3qDV5gR90zY Or if you are on a tight budget.... http://youtube.com/watch?v=iT8AZiLHsNM. Good luck!
Modified by jdmturbo1127 at 11:06 PM 8/5/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmturbo1127 »</TD></TR><TR><TD CLASS="quote">Personally I would stick with the real deal, but if you are set on doing this... I hope this helps. http://youtube.com/watch?v=3qDV5gR90zY Or if you are on a tight budget.... http://youtube.com/watch?v=iT8AZiLHsNM. Good luck!
Modified by jdmturbo1127 at 11:06 PM 8/5/2007</TD></TR></TABLE>
Thats just as bad as the vinyl stuff
red civic standard
Feb 25, 2005 12:17 PM
