oil leak from the back
Old Jul 24, 2007 | 10:17 AM
mwstrick's Avatar
Default oil leak from the back
I had all the belts and hoses replaced at 100k and ever since then I have noticed oil leaking at the back of the engine when I do an oil change.
Where or what is usually the most common oil leak problem?
97 non-vtec engine.
Old Jul 24, 2007 | 10:23 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: oil leak from the back (mwstrick)
where does the leak appear to be mostly concentrated at? Could be the oil pan gasket if the oil leak is only on the oil pan area. Maybe leaking from the oil filter is it's coming straight down the middle of the block.
need to be a little more specific on the location of the oil.
Old Jul 24, 2007 | 01:40 PM
D16Z6racing's Avatar
Default Re: oil leak from the back (TouringAccord)
Check the rear main seal too.
Filter (part $5)(labor $15)
Gasket (part $50)(labor $150 w/o oil change)
Seal (part $20)(labor $640)
Old Jul 24, 2007 | 03:40 PM
jolitaly's Avatar
clean everything up with brake cleaner and follow where the leak is coming from. the most common leak is either b/c ur oil filter is too loose or ur oil pan gasket. hondas have a tendency to leak at the oil pan gasket. it can't be the rear main b/c that's between ur transmission and the motor.
Old Jul 24, 2007 | 09:19 PM
Default Re: oil leak from the back (jolitaly)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jolitaly &raquo;</TD></TR><TR><TD CLASS="quote">it can't be the rear main b/c that's between ur transmission and the motor.</TD></TR></TABLE>
Which slowly makes its way around the oil pan...looking like oil pan gasket went bad, then drips on your a-pipe making it smell like ****. Gotta love that burning oil smell every time I get in the car. Then the smoke comes out when I put the hood to add more oil.
mrspeedy69
14
Feb 5, 2012 11:48 AM
immalooser
Sep 25, 2009 08:05 AM
tw1nny03
Mar 3, 2008 05:29 AM
anirtak
Mar 16, 2004 06:16 PM
jwiedmayer
Nov 30, 2001 07:02 AM
