New Tire already
Old Jul 24, 2007 | 08:21 AM
baldmofo's Avatar
Default New Tire already
So I put a brand new set of pirelli diablos on my bike about 4500 miles ago an the back on is gone already. I don't burn out an Im def no pro this is my first bike. The sides are pretty shot already too. When I first got the bike I took it real easy now that Im getting used to it an riding every day the weather permits me to we have been hitting up the local Mt road that have alot more twisties then most of the roads around here. Anyway is this normal for the tire to go that fast?
Old Jul 24, 2007 | 08:28 AM
marmaladedad's Avatar
The Diablos should last more than 4500 miles, unless they are the Diablo Corsa or Diablo Supercorsa. My buddy was able to squeeze three trackdays and 8k miles worth of commuting out of his Diablos before retiring them.
Are the tires at the correct psi?
Old Jul 24, 2007 | 10:30 AM
baldmofo's Avatar
Default Re: (marmaladeboy)
Yes we checked the tire psi when we put them on at the shop an I just checked the tire it the normal Diablo. I noticed that they are real sticky after a run through the the mt but just figured that to be normal. Idk either way im going to have to get a new one now
Old Jul 24, 2007 | 11:58 AM
Etylorcen's Avatar
Default Re: (baldmofo)
Diablos are fairly hard but 4500 isn't really that bad.
I've gotten less than 4k on some M1's before, granted they're a little softer but it really depends on your bike and riding style, if the tires are always properly inflated, etc.
Old Jul 24, 2007 | 01:26 PM
ptran's Avatar
Default Re: (Etylorcen)
what do tires go for? the one OP is refering to?
Old Jul 24, 2007 | 01:56 PM
3Dcycle's Avatar
Default Re: (ptran)
i got 3800 miles with current tires. back is pretty bad hope i get about 100 more miles out of it then will do it with the oil change. they are the stock tires. dunlop battlax i think. bike is a 07 919 im getting a set of avon venoms. 1 step down from the track tires. they will go by quick i think. but for cost i dont care.
Old Jul 24, 2007 | 02:13 PM
I think the Diablos go for about $200/set.
baldmofo - are you getting only one tire? Or are both equally worn out?
Old Jul 24, 2007 | 09:03 PM
Tenacious T's Avatar
I've burned up like 40-50% of my rear pilot power in 1300 miles. My front has barely worn at all.
Old Jul 25, 2007 | 04:03 AM
baldmofo's Avatar
Im just getting the back tire this time but when I put new tires on in the spring I put a new ones on both front an rear. As for the wear the front tire is worn but hardly, I noticed that it isn't as sticky as the rear after a ride. I wouldn't have expected it to be considering that there is no torque or as much weight on it
Old Jul 25, 2007 | 06:46 AM
GermanHondaSlayer's Avatar
1. Are they the regular diablos or the supercorsas?
2. What kind of bike are they on?
3. Do you exit corners hard on the throttle?
I got about 5k out of my Pilot Powers and everyone says that was a miracle. Sticky tires will wear fast.
Old Jul 25, 2007 | 08:22 AM
baldmofo's Avatar
Default Re: (GermanHondaSlayer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baldmofo &raquo;</TD></TR><TR><TD CLASS="quote"> I just checked the tire it the normal Diablo.</TD></TR></TABLE>The tires are on a 03 R6 as far as the laying on the throttle out of corners I do about half the time an the other half there are cars around so I cant. I realize that sticky tires wear faster that's why I didn't bother getting the PP I really didn't think that I would of put them to use all that well. I chose the Diablos cause I thought I would get more use an milage outta them
mike5809
Honda Motorcycles
10
Sep 11, 2006 08:44 AM
rashok
Honda Motorcycles
24
Jul 13, 2006 05:21 PM
green98civic
Honda Motorcycles
11
Jun 1, 2004 08:06 PM
Who Said
Honda Motorcycles
33
May 18, 2004 08:13 PM
pwnd
Honda Motorcycles
31
May 8, 2004 06:44 AM
