intake manifold
Old Jul 24, 2007 | 01:24 AM
16v's Avatar
16v
Default intake manifold
i have 1.5L civic, i whant change intake manifold and set manifold from 1.6VTI. must i chane ECU to set manifold from 1.6VTI?
Old Jul 24, 2007 | 05:57 AM
h22a1_julien's Avatar
Default Re: intake manifold (16v)
a 1.5l.....witch i think is a d15 from what you saying ....
The intake manifold witch is off a b16 (VTI)...does not fit...
D series dont fit with B series
Old Jul 24, 2007 | 07:48 AM
16v's Avatar
16v
1.6 SOHC VTEC manifold is also different? could i fit other manifold on stock ECU? or i have to change ECU at least
Old Jul 24, 2007 | 09:39 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (16v)
No need to change the ECU
Old Jul 24, 2007 | 10:09 AM
BlackoutVTi's Avatar
Default Re: (5_Lug_B)
I believe you're talking about the JDM 92-95 VTi, the one which also came with a SOHC engine (let me know if I'm mistaken plz). The VTi that you're talking about has the JDM D15B engine, with an intake manifold similar to the D16Z6, if not the same.
Anywho, if this is the change you're looking for, I don't think you need to change the ECU.
Old Jul 24, 2007 | 04:29 PM
jasonthehatchman's Avatar
Default Re: (BlackoutVTi)
no there is no need to change the ecu, just put the intake manifold on and adjust your idle and things of that nature cause i put a huge skunk 2 intake manifold on my jdm d15b and i had no problems but a high idle and i just adjusted, dont waste your time with changing the ecu
Matthew98DX
Oct 26, 2016 08:08 PM
advan414
Oct 1, 2014 08:36 PM
gutted
Dec 12, 2011 03:12 PM
Modulus
Honda Civic (2006 - 2015)
Sep 19, 2008 09:44 PM
Fredy
Jul 31, 2006 10:25 PM
