Intake Mani Gasket
Old Jul 23, 2007 | 06:38 PM
TMC_EF's Avatar
Default Intake Mani Gasket
I need to change my intake mani gasket and I just want to know if any one has a write up or a copy from the haynes book
Old Jul 23, 2007 | 07:17 PM
The-Kid's Avatar
Default Re: Intake Mani Gasket (TMC_EF)
Ummmm try Hondata's website on installing their gasket. I don't think they have an Accord write up, but similar. http://www.hondata.com/manuals....html Umm good luck on that. Hey! You might even make a write up too for us. =P
Old Jul 24, 2007 | 03:39 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TMC_EF &raquo;</TD></TR><TR><TD CLASS="quote">a copy from the haynes book </TD></TR></TABLE>
please read the rules...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Accord Forum Rules &raquo;</TD></TR><TR><TD CLASS="quote">10. Copyrighted Material Do not post copyrighted material on the board unless you own the rights to do so. This in particularly refers to the .pdf Helms manual and pictures you do not own the rights to. Posting a link for illegal downloadable material is also a violation.</TD></TR></TABLE>
It's not very hard. Basically, start unplugging any vacuum hose and sensor connector, make sure you mark them to make assembly easier. Depending on what car/engine you have and the way the coolant system is, you may want to drain the coolant. You'll also want to undo the gas cap to relieve pressure and unbolt the fuel feed line from the fuel rail. Unbolt the intake pipe from the throttle body and move the intake pipe out of the way. Once everything is disconnected, just unbolt the intake manifold nuts and remove the IM. Use something to scrape the old gasket off the head and install the new gasket. I've heard spraying the old gasket with WD-40 will help loosen it making it easier to remove from the head, don't know if there is any truth in that or not though. Then just reassemble everything in reverse order.
94lspower
May 9, 2007 02:53 AM
Seedc2
Apr 1, 2005 09:51 PM
EdLeake
17
Feb 23, 2004 09:08 AM
B16Hatchcx
Aug 22, 2003 12:41 PM
