Rear control arm ball joint
Old Jul 23, 2007 | 02:41 PM
Thrashed Civic's Avatar
Default Rear control arm ball joint
I did a search, but didnt find what I was looking for. My right rear tire is wearing badly on the inside tread, and after some digging around it sounds like my rear control ball joint is going out. Does anyone know if I can just replace the ball joint, or do I have to get a new rear control arm??
Old Jul 23, 2007 | 03:04 PM
janz3n's Avatar
Default Re: Rear control arm ball joint (Thrashed Civic)
there isnt a ball joint in the rear suspension.
Old Jul 23, 2007 | 03:37 PM
Default Re: Rear control arm ball joint (janz3n)
I called a tire shop and they told me that there was a joint, but thats why I'm asking here. If there isnt a joint, then is it just a simple alignment, or something else that I'm missing???
Old Jul 23, 2007 | 04:21 PM
xTimmyx's Avatar
if they told you there was a ball joint in the rear end for your car. that shop should close down. lol NOW. or just get blown up. one of the two
Old Jul 23, 2007 | 04:50 PM
.Manny.'s Avatar
Touching My Member
Default Re: Rear control arm ball joint (xTimmyx)
jack up the rear, and LOOK!
could be your trailing arm bushing. check all the bushings and upper control arm.
good luck
Old Jul 23, 2007 | 05:12 PM
janz3n's Avatar
Default Re: Rear control arm ball joint (.Manny.)
is your car lower in the rear than it is in the front? cuz a blown shock or a bad spring will lower the rear and cause a little bit of camber
Old Jul 23, 2007 | 05:55 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Thrashed Civic &raquo;</TD></TR><TR><TD CLASS="quote"> My right rear tire is wearing badly on the inside tread, </TD></TR></TABLE>
you just need an alignment.
unless of course something is bent and needs replaced. you wouldnt be able to tell unless you got an alignment anyway.
duker733
Jun 11, 2022 07:24 PM
gianinline
Sep 8, 2014 06:56 PM
Decatur Racer
Suspension & Brakes
Apr 10, 2009 08:53 PM
mingbling96
May 30, 2006 01:18 PM
