Secondary 02 sensor
Old Jul 23, 2007 | 02:27 PM
97Ej6mike's Avatar
Default Secondary 02 sensor
Im looking to wire up my secondary 02 sensor by hand, because for some reason i cant find the plug on my wiring harness ( for reasons unknown, it was that way with the swap, it came from a 96-98 civic EX).
Ive searched the topic, but have had little luck with finding anything that helps me.
Im just basically looking for a diagram of the P2P (96-98 sohc VTEC) ecu, so i can see how to wire it by hand, that is, if thats ever been done before.
Old Jul 23, 2007 | 02:59 PM
slowcivic2k's Avatar
Default Re: Secondary 02 sensor (97Ej6mike)
To wire this up correctly, you will need to do the following:
The pin designation for the ECU is listed next to the wires.
Old Jul 23, 2007 | 03:08 PM
97Ej6mike's Avatar
Thanks a bunch man, im doing this for emmisions reasons, i went from a y7 to a JDM d15b (3stage), swapped to a 96-98 EX harness. For some reason i never was able to locate the secondary o2 sensor on the harness, it may have been tampered with, so i figured it was worth a shot to wire up the sensor by hand.
Old Jul 23, 2007 | 03:40 PM
Default Re: (97Ej6mike)
There is a hole in the floorboard near the cat, I stuck mine up there when I did the OBD1 changeover, only to bite me in the as with a huge VSS/ELD problem, might want to see if they did the same thing.
m90polk1
Engine Management and Tuning
Mar 21, 2014 03:54 AM
platanaso47
13
Dec 26, 2010 05:09 AM
Ron454321
Aug 27, 2007 07:43 PM
1sikhatch
27
Feb 10, 2006 07:43 AM
shadykit
Aug 20, 2004 08:44 AM
