biggest turbo
wow...
. As big as you want... take into consideration that you many never fully spool up but hey
Check this thread out for ideas... some are running some pretty big turbos. https://honda-tech.com/zerothread?id=1833278
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixmastermatt »</TD></TR><TR><TD CLASS="quote">what is the biggest turbo you could have on a h23 with a 9.2 Comp Ratio?</TD></TR></TABLE>
why? what you should be asking is what turbo would be the most efficient for XXXwhp with 9.2 compression. you could make a turbo from a semi fit but it doesnt mean it will work very will.
very good point, i guess i worded that wrong. but what would be the most effective turbo for that ratio, my goal is to run a 12 sec 1/4 mile and i need something that has a t3 exhaust flange
