will it fit
Old Jul 23, 2007 | 02:15 PM
fastjimmy's Avatar
Default will it fit
hey i am new to this and jumped in a question earlier trying to help. but i have a question if 215-50-15 tires will fit on my 99 si. i have 15-6.5 konig heliums on it with 205-50-15s now. i also no 215s ar 1/2 inch wider . it looks like i have clearance on both sides.
Old Jul 23, 2007 | 02:20 PM
FalkenSiR's Avatar
Default Re: will it fit (fastjimmy)
they will fit but that's the wrong size for your car. The only cons of this are they will probably rub (if car is not stock height), and your speedometer will be off.
Just be aware that wider doesnt mean it sticks better. You can get a skinny tire that sticks better than a bigger one.
Old Jul 24, 2007 | 11:09 AM
Suk02Si's Avatar
Default Re: will it fit (FalkenSiR)
The sidewalls may bulge out a little too much if you run a 215 on a 6.5" wheel; stick with the 205.
Old Jul 24, 2007 | 07:20 PM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">they will fit but that's the wrong size for your car. The only cons of this are they will probably rub (if car is not stock height), and your speedometer will be off.</TD></TR></TABLE>
Actually, the 215/50-15 has the same outer diameter as the stock size for your car. So the speedometer won't be off. However, they WILL rub. And furthermore...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FalkenSiR &raquo;</TD></TR><TR><TD CLASS="quote">Just be aware that wider doesnt mean it sticks better. You can get a skinny tire that sticks better than a bigger one.</TD></TR></TABLE>
That's the REAL problem with 215/50-15. The only tires made in that size are really crappy. So you'll get better performance (and at a lower price) with tires in 195/55-15 or 205/50-15.
DC2 12
Honda Civic (2001 - 2005)
Aug 24, 2006 12:20 PM
serialz_1
Jun 7, 2006 10:41 PM
bard329
Dec 3, 2005 11:24 PM
D-series ninja
Jun 9, 2005 10:56 PM
integlspwr2k
20
Jun 16, 2004 04:48 AM
