dyno numbers?
Old Jul 23, 2007 | 01:15 PM
egredspools's Avatar
Default dyno numbers?
just had my car dyno and i got 165.2hp at 10lbs but some cylinder 1 code 9 cyp keeps popping up would that cause the motor to stay in limp mode or not let the hondata tune right?
The motor:
D16Z6
greddy kit at 10lbs
arp head studs
skunk2 titanium springs an retainers
skunk2 cam gear an intake manifold
zex stage 2 cam
no name front mount(covers whole front)
3 bar map
inline pro 370cc injectors
inline 2mm headgasket
3inch thermal exhaust
2.25in-2.50in-3.00in downpipe
Any input would be usefull!!!
Old Jul 23, 2007 | 01:29 PM
Syndacate's Avatar
Default Re: dyno numbers? (egredspools)
Read it wrong, nvm, sorry.
Old Jul 23, 2007 | 01:54 PM
slowcivic2k's Avatar
Yes, the Cylinder Position Sensor is used to determine fuel timing, and if this is wrong, it will base it off of the TDC sensor, which equals really crappy fuel injection, might as well put a carbuerator on there.
The sensor is internal to the distributor, and if you swapped it, you might want to double check your wiring, they normally don't go bad.
Old Jul 25, 2007 | 08:08 AM
Default Re: dyno numbers? (slowcivic2k)
going to change the distributor and see what numbers i get from that!
eg6 type-R
38
Jan 5, 2012 11:10 PM
i-VTEC_DOHC
Honda Civic (2006 - 2015)
27
Mar 28, 2010 07:55 PM
egredspools
Jul 25, 2007 08:08 AM
RIP V8s
44
Jun 7, 2007 12:28 PM
mod5
Aug 22, 2002 01:26 PM
