Does CEL 22 mean i need an oil change?
Old Jul 23, 2007 | 01:00 PM
meangreenEG's Avatar
Default Does CEL 22 mean i need an oil change?
My CEL popped on a couple days ago. I checked it and it was code 22, meaning it is the VTEC oil pressure switch. Does this mean either oil is leaking from somewhere, or i need an oil change?
Old Jul 23, 2007 | 01:03 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: Does CEL 22 mean i need an oil change? (meangreenEG)
Did you examine the switch?
How's your oil level?
When it comes to vtec, it's not so much the oil as the quantity. No honda sensor will tell you if your oil needs to be changed.
Old Jul 23, 2007 | 01:07 PM
Default Re: Does CEL 22 mean i need an oil change? (ek forever guy)
Is the switch located below the solenoid? And I do have enough oil.
Old Jul 23, 2007 | 01:08 PM
Ek Forever y0!
Then I would say you either have a faulty switch or somethings F'ed the wiring, more likely the switch.
Old Jul 23, 2007 | 01:15 PM
Should i replace the switch? If so, where could i get one?
Old Jul 23, 2007 | 01:23 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">Should i replace the switch? If so, where could i get one?</TD></TR></TABLE>
Check the oil screen first. It's probably just clogged up.
Did you do any recent mods, this a new swap? Anything like that? Did this just start? Any catalysts (like a parts change) right before this?
Old Jul 24, 2007 | 05:58 AM
Default Re: Does CEL 22 mean i need an oil change? (Syndacate)
Sorry for being a n00b , but where do i check for the oil screen?
No, this is my stock D15Z1.
Old Jul 25, 2007 | 08:18 AM
bump
Old Jul 25, 2007 | 08:33 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">Sorry for being a n00b , but where do i check for the oil screen?
No, this is my stock D15Z1.</TD></TR></TABLE>
you have to remove the vtec solenoid from the head, there you will find the screen.
Old Jul 25, 2007 | 08:52 AM
Default Re: Does CEL 22 mean i need an oil change? (philosofy1)
Will this create a mess? How difficult is it to remove the VTEC solenoid. I did a search on it and some people said it only caused more problems trying to put it back. Any ideas on what i should do ?
Old Jul 25, 2007 | 09:03 AM
philosofy1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by meangreenEG &raquo;</TD></TR><TR><TD CLASS="quote">Will this create a mess? How difficult is it to remove the VTEC solenoid. I did a search on it and some people said it only caused more problems trying to put it back. Any ideas on what i should do ?</TD></TR></TABLE>
oil will leak out. it is easier to remove it, check the screen, and replace if necessary, than having to search and buy a whole new/used solenoid.
the screen is only $24 at the dealer, the solenoid is $300.
dc4teg95
Feb 19, 2007 03:34 PM
s2kkk
Honda S2000
Feb 17, 2007 07:37 AM
danny98r
Nov 10, 2004 07:08 AM
obd1gsr
Dec 25, 2003 09:48 PM
Hatch-E
Dec 23, 2003 09:08 AM
