broke old tranny...want a better one?????
Old Jul 23, 2007 | 11:08 AM
2001turbobluelude's Avatar
Default broke old tranny...want a better one?????
I basicly destroyed my stock tranny in my 01 lude base, I want to upgrade to LSD....what do you experts out there recomend??
Old Jul 23, 2007 | 12:02 PM
98vtec's Avatar
moderator emeritus
Default Re: broke old tranny...want a better one????? (2001turbobluelude)
M2A4
Quaife
Gearspeed carbon coated synchos
Mfactory 4.62 FD
no expert, but thats what i want.
Old Jul 23, 2007 | 12:32 PM
MLBZ521's Avatar
Default Re: broke old tranny...want a better one????? (98vtec)
98vtec, Any reason for the M2A4? Say over the F4 or Y4? Well, the M2Y4 has completely different gear ratios actually...
Your reason for the 4.62 FD over the 5.2 FD (Correct..?) on the market..? Save some gas??
Everything else is understandable.. Heh
Oh, just wondering if anyone would know if a Quaife fit in a T2W4??
Bah forgot, and to the OP.. Get what sounds best to you and for your budget.. It also depends on what you are going to be using the car for..
I have a M2B4 that I'm thinking about selling... Contact me if you're interested..
[Edit: Missed typed the M2Y4 Tranny code.]
Modified by MLBZ521 at 2:50 PM 7/23/2007
Old Jul 23, 2007 | 12:45 PM
98vtec's Avatar
moderator emeritus
Default Re: broke old tranny...want a better one????? (MLBZ521)
why pay extra for an LSD tranny when the gears between the two are the same and your gonna replace the stock LSD with a quaife.
Old Jul 23, 2007 | 12:49 PM
MLBZ521's Avatar
Eh??? Gears between which two Tranny's are the same??
A4, F4, and Y4 are all Non-LSD and the T2W4 is LSD yes, but it doesn't have the same gears as any of the previous Tranny's...
M2A4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266
M2B4 - 3.307 - 1.950 - 1.360 - 1.034 - 0.787 - 4.266 LSD
M2F4 - 3.307 - 1.950 - 1.360 - 1.071 - 0.870 - 4.266
M2Y4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266
T2T4 - 3.285 - 1.956 - 1.344 - 1.034 - 0.812 - 4.266 LSD
T2W4 - 3.285 - 2.090 - 1.481 - 1.071 - 0.812 - 4.266 LSD
U2Q7 - 3.285 - 2.090 - 1.481 - 1.071 - 0.870 - 4.266 LSD
Thinking maybe of the T2T4??
Old Jul 23, 2007 | 12:53 PM
MLBZ521's Avatar
I didn't meant imply that I would buy a LSD Tranny and replace it with a Quaife, just asking.. Everyone wants to know if a M2B4 LSD Unit, or any other stock LSD Unit, will fit in a USDM or Non-LSD Tranny Case.. So just wondering if a Quaife would fit in a Stock LSD Tranny Case, although, now that I think about it, why wouldn't it...? Heh
Old Jul 23, 2007 | 01:09 PM
gogunkergorilla's Avatar
damn another tranny debate ...
it depends on what has been done to the engine for teh 100000000000000nth time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">
i can tell you the case is different (bigger), so probably no it will not fit properly...
OP...i have a t2w4 that i will be selling as soon as i get a chance to take it off. lemme know if you are interested..
Old Jul 23, 2007 | 02:47 PM
vinuneuro's Avatar
Quaife unit will not fit in the M2B4.
Modified by vinuneuro at 10:48 PM 7/23/2007
Old Jul 23, 2007 | 02:48 PM
MLBZ521's Avatar
Default Re: broke old tranny...want a better one????? (vinuneuro)
Discussed where?
Old Jul 23, 2007 | 07:25 PM
vinuneuro's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MLBZ521 &raquo;</TD></TR><TR><TD CLASS="quote">^^???
Discussed where? </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=930807
Old Jul 23, 2007 | 10:45 PM
MLBZ521's Avatar
No no.. I didn't mean it like that.. Heh
I was asking where was that discussed in this thread?? We never mentioned the M2B4 + Quaife in here..
Old Jul 23, 2007 | 11:04 PM
TylerC161's Avatar
Well Im very interested in this subject also. Im looking into replacing my transmission here soon with someone else. currently its m2a4, and from the gearing charts it'd make sense to get the U2Q7 for wanting short gearing and race, but how hard are those to find? And they install in a prelude right? Im in a 4th gen h22a right now. Would I have better luck getting a T2W4 since its so close in gearing? What are the costs of said transmissions?
Old Jul 24, 2007 | 05:23 AM
Default Re: (TylerC161)
I'm running a m2y4 stock and just want to start over with something else. car is turbo'd just looking to keep the tires in contact with the ground. M2B4 sound good and where can I get a good one.....will the stock axles work? first time tampering with honda tranny....thanks
Old Jul 24, 2007 | 06:04 AM
Silver Surfer's Avatar
Default Re: (2001turbobluelude)
if you're turbo'd then you might want to look at some of the trannies with longer gears unless you are strictly looking at the stock lsd and $$ concerns of an aftermarket
Old Jul 24, 2007 | 06:29 AM
Default Re: (Silver Surfer)
I'm open for sugestions. I just need to get the car back together and can't really afford an aftermarket LSD and a new tranny. Longer gears are fine for me, the cars got the power to pull through them....
Old Jul 24, 2007 | 11:07 AM
txihondatec2's Avatar
i was told lsd don`t really hold up on fwd applications .i`m looking for 10 sec e.t what type of gearing would people really be reecommend? i wanna still max out at 150 or sumthing higher i was told 5th gen trannies climb to those speed is it possible to get the best of both worlds with stock.
Old Jul 24, 2007 | 11:12 AM
98vtec's Avatar
moderator emeritus
Default Re: (txihondatec2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by txihondatec2 &raquo;</TD></TR><TR><TD CLASS="quote">i was told lsd don`t really hold up on fwd applications .i`m looking for 10 sec e.t what type of gearing would people really be reecommend? i wanna still max out at 150 or sumthing higher i was told 5th gen trannies climb to those speed is it possible to get the best of both worlds with stock.
better do your own research and development then. I highly doubt many of the people here will give out their hard earned secrets without you doing your homework.
Old Jul 24, 2007 | 11:37 AM
Default Re: (98vtec)
thats fair
Old Jul 24, 2007 | 12:45 PM
MLBZ521's Avatar
Yea, Turbo better with longer gears and NA is better with Shorter gears, so the saying goes..
2001turbobluelude, I have a M2B4 Tranny that I'm selling.
Contact me at my E-Mail since you can't PM.
MLBZ521@ScorchGaming.com
Old Jul 24, 2007 | 06:37 PM
Boarderx192's Avatar
Default Re: (MLBZ521)
I have an M2A4 tranny with a Quaife already installed that Im getting rid of. Check out the FS section the Prelude section
Old Jul 24, 2007 | 07:43 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
Default Re: (Boarderx192)
I got a mint oem trans out of a 99 base lude
600
local as well
Old Jul 25, 2007 | 04:40 AM
Default Re: (MugenHonda)
Hey, you had the M2A4 installed on your 98 5th gen? Axles and everything work fine with that? and what are you looking to get for it. you can email me at: floridafund@fastmail.fm Thanks
Old Jul 25, 2007 | 06:26 AM
mugenhonda....Whats your location with that tranny and how many miles are on it?
Jimster480
Transmission & Drivetrain
26
Apr 16, 2010 05:40 AM
JaredMonkey
Nov 11, 2005 01:15 AM
anfrey
Nov 11, 2004 08:07 AM
Black R
May 11, 2003 07:53 AM
