Help: Shifter noise
Old Jul 23, 2007 | 06:47 AM
garyc17's Avatar
Default Help: Shifter noise
Ever since I swapped out my stock OEM shifter bushings with Energy ones, there is a vibration noise coming from my shift ****. Is this normal for Energy bushings or did I overlook something? Checked my shift **** and it is well secured.
Old Jul 23, 2007 | 11:47 AM
The Kernel's Avatar
Default Re: Help: Shifter noise (garyc17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Ever since I swapped out my stock OEM shifter bushings with Energy ones, there is a vibration noise coming from my shift ****. Is this normal for Energy bushings or did I overlook something? Checked my shift **** and it is well secured.</TD></TR></TABLE>
That sounds ok. I get a slight vibration with the mugen bushings about 4-5k rpm also. Energy bushings are harder so they probably make more noise.
Old Jul 24, 2007 | 08:51 AM
garyc17's Avatar
Default Re: Help: Shifter noise (The Kernel)
The sound of vibration appears only after 7000rpm for me. Was considering putting the stock bushings back because the energy wants don't really seem to do much to the shift feel.
Old Jul 24, 2007 | 09:15 AM
Erik95LS's Avatar
mine made a major difference in shift feel. Feels very solid and mechanical like the s2000 shifter. No vibrations or noise here though.
Old Jul 26, 2007 | 07:18 AM
garyc17's Avatar
Maybe my engine mountings are weak, resulting in engine shifting while driving. Therefore the shifter feel doesn't maintain. It feels solid at times, but sticky sometimes. Especially into 2nd.
Old Jul 26, 2007 | 08:07 AM
JjuuN R's Avatar
Default Re: (garyc17)
That's a possibility...
Old Aug 2, 2007 | 08:26 AM
garyc17's Avatar
Default Re: (JjuuN R)
Which of the mounts would be the problem? Or should I replace them all?
Old Aug 2, 2007 | 07:37 PM
JjuuN R's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Which of the mounts would be the problem? Or should I replace them all?</TD></TR></TABLE>
Don't replace any of them until you know they're bad. Just looks for cracks or imperfection in the rubber parts of each of them.
Old Aug 3, 2007 | 05:01 AM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">Which of the mounts would be the problem? </TD></TR></TABLE>
Inspect the rear tranny mount first.
Old Aug 4, 2007 | 02:19 AM
garyc17's Avatar
The SO4 wordings on the mounting at the timing belt is slightly stretched at an angle. Can this be a symptom?
Old Aug 4, 2007 | 06:04 AM
neo_'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garyc17 &raquo;</TD></TR><TR><TD CLASS="quote">The SO4 wordings on the mounting at the timing belt is slightly stretched at an angle. Can this be a symptom?</TD></TR></TABLE>
What?
Old Aug 4, 2007 | 11:38 AM
dc2josh's Avatar
Default Re: (neo_)
just make sure your bolts aren't super tight and put generous amounts of grease on those bushings
Old Aug 13, 2007 | 08:21 AM
garyc17's Avatar
There is still vibrations transmitted all the way to the gear stick. Changed the front bushing at the tranny to a oem one and no more vibration/rattling. The rear ones are still energy.
azhfreak
Aug 1, 2007 12:10 AM
poisonousbeef
Jul 21, 2006 09:20 AM
hlee5363
Nov 9, 2005 02:56 PM
loclowd
Oct 10, 2005 11:40 AM
nijia555
Apr 23, 2003 01:25 PM
