Manifold swap, car won't start
i have a d16y7 with auto tranny and swapped in a y8 manifold from a 5spd 96-98.
everything seems to be plugged correctly and the engine is turning over but it won't start. The Cel doesn't come on either.
heres a list of everything used:
5spd y8 manifold w/ iavc blocked off
y7 throttle body with y8 TB rotor
y7 manifold gasket
new hoses.
pics of the connections
y7 manifold gasket
new hoses.
just a quick question? Y do u have the iavc blocked off? i can not see the pic bc im at work and it does not pic it up for some reason anyways.
well.. ideas.. since u havent said what you've done to see why it doesnt work i guess we'll start with some basic ideas..
after turning it over a whole **** load of times go pull a plug out n smell it.. got milk? i mean gas?.. if so
next let gas go away dont want to make fire.. fire = not fun.. so once gas goes away test ur plugs.. got milk? damnit i mean spark ? if so
sooo gotta gues u dont got air then...
try opening up the idle screw all the way maybe? or popping a hose maybe ur floodin it out eh?
Iloveyourhonda92
Mar 25, 2010 01:39 PM
Cashieboi
Oct 20, 2006 08:38 PM
