too much wheel hop!
replace motor mounts with solid units or install some inserts at least. and you could also try one of those dampening units- looks like a little shock absorber that fits on the motor mount. yes its not good for your car to have bad wheelhop.
I have the same problem on the track and i have hasport mounts.... I was about to try a traction bar, what do you think?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicsaremean »</TD></TR><TR><TD CLASS="quote">i have too much wheel hop and it makes it hard to burn out! how do u reduce wheel hop! what does wheel hop mean? is it bad????????????</TD></TR></TABLE>
so you have wheel hop, but you dont know what it means....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mike-Eg6 »</TD></TR><TR><TD CLASS="quote">mounts or your car is to high</TD></TR></TABLE>
Car height doesn't have any meaningful effect on wheel hop.
Traction bar, H brace, or mount inserts will help.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek forever guy »</TD></TR><TR><TD CLASS="quote">
Traction bar, H brace, or mount inserts will help.</TD></TR></TABLE>
second that also tires make a difference and do you have a LSD? most likely not so look at that also.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">Tires
Alignment
motor mounts
suspension
</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thesmogman »</TD></TR><TR><TD CLASS="quote">Add to list: Struts.</TD></TR></TABLE>
Suspension = Struts
Alignment
motor mounts
suspension
Suspension = Struts
I once broke a spring iin my front left side on my mx3. It was so bad. I went to do a burn out and the bitch bounce like it was on hydraulics.
IT was funny .
IT was funny .
new struts, lsd, solid mounts all sound like a good idea if its a huge problem for you. also maybe u just need to get the tire spinning faster so it wont hop. haha.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by electron_si »</TD></TR><TR><TD CLASS="quote">
x1000000000000000000
Noob
Noob
elitesi8
Oct 9, 2005 06:42 AM
