Honda Minivans, Crossovers, and Trucks Honda Odyssey / Ridgeline / Pilot / HR-V
Acura MDX / RDX
1997 crv (stock engine) hesitates
Old Jul 22, 2007 | 10:51 PM
blum116's Avatar
Default 1997 crv (stock engine) hesitates
my crv tends to hesitate, losses power and a popping noise from intake while i'm driving. i changed plugs, plug wires, fuel filter, rotor n cap. the car idles perfect and all fluids are fine. help!!!
Old Jul 23, 2007 | 03:45 PM
Aahj's Avatar
Default Re: 1997 crv (stock engine) hesitates (blum116)
did you put a timing belt on the car recently?
Old Jul 23, 2007 | 05:49 PM
blum116's Avatar
Default Re: 1997 crv (Aahj)
Aahj, no i did not. i was trying to bypass that thought, hopeing it was a simpler problem. will changing the belt solve the problem? thanks
Old Jul 24, 2007 | 07:10 PM
Aahj's Avatar
Default Re: 1997 crv (blum116)
no, but if one was installed recently, it could have been a tooth off and will cause this symptom...it never hurts to check the timing anyway just to make sure.
AJ
Old Jul 24, 2007 | 09:09 PM
blum116's Avatar
AJ, i'll check it first. thanks!!!
Old Jul 25, 2007 | 04:38 PM
Aahj's Avatar
No worries...good luck!
Old Jul 27, 2007 | 08:57 PM
phootbag's Avatar
The years of CRV's near yours and including have notorious problems with exhaust valves receeding into the cylinder head. The valves end up staying open and reducing compression far below limits. Worst case is the valves are burned and you must replace the cylinder head. Best scenario is that you can adjust the valves and put off replacment of the head for a while... I have a bad feeling that this is your problem.
Old Jul 27, 2007 | 09:20 PM
blum116's Avatar
Default Re: 1997 crv (phootbag)
phootbag, thanks for the info. is there a way to check this problem(compression test?).
Old Jul 28, 2007 | 03:48 PM
phootbag's Avatar
I would do a compression test. If it is bad, perform a valve lash inspection. If you find tight valves and can get adjust them without the adjuster bottoming out then do another compression test. Once the valves are adjusted properly a second compression test will tell you if one or more valves are burned. Probably not even worth doing a wet/dry compression test since these engines have such a common problem with the whole exhaust valve issue.
Old Aug 8, 2007 | 09:26 PM
blum116's Avatar
phootbag, thank again for info. will do this test and will get back with you.
PURPLERANGER
Aug 9, 2014 05:43 AM
808Breaker33
Classic Hondas
Feb 1, 2013 08:51 PM
showmerider
Mar 17, 2010 11:32 AM
H22*CiViC
Feb 11, 2010 04:52 PM
vtec.dc2
Mar 14, 2007 11:58 AM
