what is the tire size for 99-00 si rims??
Old Jul 22, 2007 | 05:41 PM
ShinotakuX's Avatar
Default what is the tire size for 99-00 si rims??
I bought a set of 00 si rims recently with no tires, and would like to know what size tires would fit the rims best. Car is 96 civic ex lowered on agx/sportline.
Old Jul 22, 2007 | 07:31 PM
tha_badguy's Avatar
Old Jul 22, 2007 | 11:35 PM
kjmagnum's Avatar
or you could get 205/50R15.
Old Jul 23, 2007 | 01:52 PM
fastjimmy's Avatar
Default Re: (kjmagnum)
first i will tell you 205-50-15 will fit fine i have them on my 99 civic si. now someone tell me if i can go to 215-50-15 it is only 1/2 inch wider will they fit thanks.
Old Jul 24, 2007 | 09:43 AM
HONDA RR's Avatar
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">195/55/15</TD></TR></TABLE>
You could also go 195/50/15 .
Old Jul 24, 2007 | 02:13 PM
ShinotakuX's Avatar
Default Re: what is the tire size for 99-00 si rims?? (ShinotakuX)
195/50/15 or 195/55/15????
Old Jul 24, 2007 | 04:44 PM
Voyage34's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ShinotakuX &raquo;</TD></TR><TR><TD CLASS="quote">195/50/15 or 195/55/15????</TD></TR></TABLE> 195/55/15 is the proper size for your car, with 205/50/15 being the next best (though slightly less ideal as far as speedo/odo &gearing)
195/50/15 is nearly 1" smaller OD than stock, and so will throw off your spedometer, fu<U></U>ck with your effective gearing, and look undersized/stupid
Old Jul 24, 2007 | 07:49 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: what is the tire size for 99-00 si rims?? (Voyage34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastjimmy &raquo;</TD></TR><TR><TD CLASS="quote">first i will tell you 205-50-15 will fit fine i have them on my 99 civic si. now someone tell me if i can go to 215-50-15 it is only 1/2 inch wider will they fit thanks.</TD></TR></TABLE>
No. 215/50-15 will rub. Also, the only tires available in that size are really crappy, and won't perform as well as good tires in 195/55-15 or 205/50-15.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 &raquo;</TD></TR><TR><TD CLASS="quote"> 195/55/15 is the proper size for your car, with 205/50/15 being the next best (though slightly less ideal as far as speedo/odo &gearing)
195/50/15 is nearly 1" smaller OD than stock, and so will throw off your spedometer, fu<U></U>ck with your effective gearing, and look undersized/stupid </TD></TR></TABLE>
Old Jul 29, 2007 | 03:19 PM
ChadB's Avatar
205/50-15 FOR SURE.
Old Jul 30, 2007 | 11:18 PM
bmoua's Avatar
205/50/15's would fit perfect bro...i've got Si's also and i'm running 205/50/15's.
Old Jul 31, 2007 | 01:35 AM
Doostur's Avatar
195/55/15 or 205/50-15
Old Jul 31, 2007 | 05:21 AM
Quick99Si's Avatar
Default Re: (Doostur)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Doostur &raquo;</TD></TR><TR><TD CLASS="quote">195/55/15 or 205/50-15</TD></TR></TABLE>
Yeah... 205/50 is typically cheaper than 195/55. 195/50 is almost retarded IMO.
Adi
Old Jul 31, 2007 | 09:28 AM
nsxtasy's Avatar
H-T Order of Merit
Default Re: (Quick99Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quick99Si &raquo;</TD></TR><TR><TD CLASS="quote">Yeah... 205/50 is typically cheaper than 195/55.</TD></TR></TABLE>
Often, but not always. For example, the popular Yokohama ES100 is a notable exception.
TailZ
Apr 28, 2008 03:08 PM
ShinotakuX
37
Sep 17, 2007 07:38 AM
AiL45
Dec 22, 2006 06:59 AM
4drITR
Apr 20, 2006 08:56 PM
90teg
15
Nov 3, 2005 07:25 AM
