B Series Manifold Downpipe Injectors Turbo parts...
I want to do some upgrades on my car so here are the parts i have taken off or from old setups.
More pics on my site http://kevinbomers.sentimental...e=all
Inline Pro cast stainless steel T3 flanged 5 bolt turbo exhaust manifold. In great condtion complete with all Grade 8 and stainless nuts,bolts, lock washers, for turbo, downpipe and wastegate. sold would liek to sell with one of the down pipes
KGB Fab 3.0 Down pipe for inline pro t3 5 bolt manifold Will NOT clear A/C. 3.0 mild-steel mandral bends, butt welded, no slip fit. (2) o2 bungs, 3 bolt flange, 6in mesh flex section (All parts for this where bought from ATP turbo no junk) sold
KGB Fab Dumptube 1.5 for Inline Pro manifold Goes under oil pan and stops where your cat would bolt up. OPEN DUMP. sold
KGB Fab Intake tube to turbo 3.0 mild-steel mandral bends butt welded. painted black for Inline Pro 5 bolt manifold. sold
Inline Pro SS Down Pipe Clears PS/AC. Has EGT bung welded in. I also have a 3 Bolt flange for the end. 125.00
Garrett turbo t3 .48 .60 off a nissan 300zx. needs rebuild for sure. 75.00 SHIPPED
Precision 660cc injectors Peak and hold. Came with my car, I need bigger ones. 185.00 SHIPPED
Upper charge pipe for eg/ek may fit ef's. 2.5 mild-steel mandral bends, butt welded, with 1st gen DSM bov. 55.00 SHIPPED
Oil fitings/lines
5/8 oil drain high temp silicone.
(2) 5/8 fittings for oil drain.
Oil inlet for Garrett GT series tubro
oil fitting from block
oil fitting 90 degree
55.00 SHipped bought from ATP turbo
VDO black boost gauge 30vac/30psi. Gauge is dead on. i compared to my data log sheets when i was tuning. SOLD
New 3.0 Stainless N1 style muffler with silencer. Is ment for eg hatch has hangers and some pipe. Looking for SOLD
Water Lines for Turbo Two lines, two fittings. 6an hose 3/8 barb Bought from ATP turbo never used.
Modified by KevronsEG at 11:34 AM 7/26/2007
Modified by KevronsEG at 10:05 AM 7/28/2007
Modified by KevronsEG at 4:50 PM 7/29/2007
Oil fitings/lines
BoostFlow.com
Nov 2, 2011 10:00 PM
project dc2
Sep 6, 2004 12:22 PM
