best way to remove block coolant drain plug on D series?
Old Jul 22, 2007 | 05:02 PM
quapouh's Avatar
Default best way to remove block coolant drain plug on D series?
Location of this fu**n plug is horrible, anyone with a suggestion what to use on it to get best access and leverage? tried some from underneath but no luck ... engine is d16y7 with top feed TB so maybe for a better acces I should remove the filter box? HELP :d ... I know it's stupid but i want to do job right not just half ***
Mike
Old Jul 23, 2007 | 12:21 AM
Mista Bone's Avatar
D Tranny Guru
remove exhaust manifold, now easy to get an impact on it.
Old Jul 23, 2007 | 09:03 AM
quapouh's Avatar
Default Re: (Mista Bone)
ehm ehm ... It's a D series block ... drain plug is at the back of the block ... B series got i in front on the Dizzy side ... Guru
Still waiting for hints
Mike
Old Jul 23, 2007 | 11:18 AM
Mista Bone's Avatar
D Tranny Guru
really???????
My D15B7 and D16Z6 had the drain plugs on the FRONT of the block.
Look down between #3 and #4, that 1/2 head you see behind the webbing on the front of the block is the drain plug
D16Z6
D15B1/2/6/7/8 = in front of #3
Old Jul 23, 2007 | 11:20 AM
Mista Bone's Avatar
D Tranny Guru
Maybe on the Y's they put them on the back.........since they screwed everything else up on that motor.
Old Jul 23, 2007 | 11:33 AM
wiZCo's Avatar
Stouts 'n' Scotch
They're on the front of D16A6s and DOHC ZCs as well.
Old Jul 23, 2007 | 01:42 PM
teamworxek9's Avatar
isnt that the oil fliter base i see right there on the back of the block behind #3
Old Jul 23, 2007 | 01:50 PM
Syndacate's Avatar
Default Re: (teamworxek9)
Ahahaha, coolant drain plug!!
Just remove both rad hoses from the block, thermostat, and the petcock from the rad.
Stick a garden hose in top radiator hose until clear water falls out the bottom of the radiator, then do the same with the bottom rad hose. That'll clean both rad hoses and the radiator.
Turn the ignition on - set the heater to "heat" so it opens the heater valve. Then turn it off. Stick garden hose in hole on top of block, let it sit for 10 minutes. That'll clean the block and heatercore - if you're really self-conscious about it - after you turn on the heater and are running coolant through it - start it up and let it idle for a few minutes, just watch the temp gauge.
Put it back together and fill it back up.
LoL - Removing the header....coolant drain plugs..impact wrenches....ahahhaha....
Modified by Syndacate at 6:07 PM 7/23/2007
Old Jul 23, 2007 | 01:52 PM
THC07's Avatar
Default Re: (Syndacate)
ahahahhahahha he says!
method gets a
I didnt even try to find my plug on the H. Just did this last week, same way as synd explained.
Old Jul 15, 2016 | 09:57 AM
Omega Blaze's Avatar
2016 Bump. So you just flush out the top radiator hose hole on the block for 10 minutes correct?
Old May 7, 2018 | 09:28 AM
Steffano's Avatar
Default Re: best way to remove block coolant drain plug on D series?
1.) Remove petcock from radiator, located at the bottom of the radiator passenger side(assuming the vehicle is left-hand drive). The petcock should be finger tight and easily removable with your finger. Allow as much nasty coolant and water to drain out as possible.
2.) Once fully drained, reinsert petcock into radiator and tighten ONLY USING HANDS. NO TOOLS!!
3.) Remover the clamp on the upper radiator hose. Either side is fine, whether from the radiator or from the engine block.
4.) Once hose is undone, turn on vehicle and allow to idle until temperature needle begins to rise. Make sure to turn the heater on up to maximum capabilities. You may speed up the process by increasing the RPM's. However, once it begins to rise, let idle, get out of the car and turn on a hose with fresh, cool, constant flowing water.
5.) Leave driver window open and watch the temperature gauge. ONLY when the needle reaches the middle of the gauge AND ONLY THEN will you jam the hose into THE RADIATOR!! Water will then flow through the radiator, past the open thermostat, through the heater core and all the other filthy coolant lines of the car. You will be able to see this gunk coming out nice and warm/hot from the cylinder head where the upper radiator hose connects to. Try to create pressure with your hose by making sure it is sealed and water is not back flowing onto your hand. Try to make sure EVERY DROP goes in through the radiator and out the motor. The temperature may go down quite quickly. Continue this until the water coming out the motor is basically clean and clear.
FOR BEST RESULTS, REMOVE THERMOSTAT AND PUT HOUSING AND HOSE BACK TOGETHER CAREFULLY WITHOUT OVER TIGHTENING!! ONCE FLUSH IS COMPLETE, OPEN HOUSING AND RETURN OR REPLACE THERMOSTAT. BE CAREFUL WHEN RE-TIGHTENING THOSE BOLTS!
Old May 8, 2018 | 11:53 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
That's great but then how do you get the water out so you can fill with the proper 50/50 coolant mix?
spoolinvtec54
Engine Machining & Assembly
Oct 29, 2018 09:15 AM
rich7777
Aug 30, 2010 02:32 PM
digital sol
Welding / Fabrication
Jun 26, 2007 10:35 AM
