Fuel Tank Removal
Installing a new tank and need to remove the old one. Service manual I have says I need to relieve the fuel pressure by using a 6mm on the fuel filter. Only problem is I dont know where the fuel filter is. Any help on location?
I just removed two tanks this week. I thought it was pretty easy to do. Just unplug the two connectors under the covers from the inside of the car and the fuel line with the clip on it. The hardest part i thought was getting the rubber hose off the fuel tank where the fuel filler neck is.
Well im not sure what yr. teg u have but on my 93' it was on the top left of the firewall inside the engine bay. There should be a line that comes off the fuel rail so just follow that and see where it leads u. Good Luck.
OH_1fstgsr
May 3, 2010 03:27 PM
vietintegboi
Oct 19, 2006 07:33 AM
all420
Mar 5, 2003 10:17 AM
