brake lights, turn signals, cluster wont work ....
Old Jul 22, 2007 | 02:34 PM
Phils's Avatar
Default brake lights, turn signals, cluster wont work ....
the lights on my cluster went out and they haven't been working for awhile now so i tried to replace the bulbs still the cluster didn't work and on the dash below the cluster is an adjustable **** to adjust the dimmer of the needle/lights for the fuel and the oil temp ... i barely moved those wires going to it and i heard a tick ... then the brake lights wont work or my turn signals either. can anyone please help me... and still after all this the lights on my cluster are still out and will not turn on .... thanks for the help
Old Jul 22, 2007 | 03:17 PM
xanonymousx's Avatar
Default Re: brake lights, turn signals, cluster wont work .... (Phils)
The only time my gauge cluster in my car went out was when the relay had to be replaced.
Old Jul 23, 2007 | 05:11 PM
Phils's Avatar
Default Re: brake lights, turn signals, cluster wont work .... (xanonymousx)
where is he relay how much does it cost to replace ???
Old Jul 24, 2007 | 07:31 PM
Phils's Avatar
is that dimmer also a relay?
Old Jul 25, 2007 | 03:40 PM
My relay for my cluster is just hanging under the dash so I don't know where the original spot is but just look under there. It's a small black box that you can unplug. They are cheap to replace.
Old Jul 25, 2007 | 08:11 PM
sam0218's Avatar
did you check the fuses? cluster fuse should be under the dash and the one for the brake lights should be under the hood
Old Jul 25, 2007 | 08:12 PM
pandarex's Avatar
Default Re: brake lights, turn signals, cluster wont work .... (sam0218)
fuse, if i remember right there all on the same fuse.
Old Jul 27, 2007 | 11:58 AM
sam0218's Avatar
Default Re: brake lights, turn signals, cluster wont work .... (pandarex)
brake lights and horn are on one fuse that is under the hood, and for the others i think it might be 2 or so fuses under the dash
slammed ej8
Nov 29, 2009 07:09 PM
furiousbob
Dec 14, 2008 11:46 PM
egb18crt
Apr 1, 2007 09:26 PM
honda011
11
Aug 31, 2005 07:14 PM
hybrid901
Jan 30, 2003 04:40 PM
