2 random questions (insurance and alignment)
Old Jul 22, 2007 | 02:18 PM
WhiteOnRice's Avatar
Default 2 random questions (insurance and alignment)
First, I was wondering if anyone lets their insurance company know about the mods they do to the car and gets them insured? If anyone does, how much does your insurance go up?
Second, can I get an alignment done (at Tires PLus) if I have a DCRH (no cat)?
Old Jul 22, 2007 | 04:33 PM
phthalo's Avatar
GDD4LIFE
Default Re: 2 random questions (WhiteOnRice)
how much the insurance is depends on what company you have. i'm sure everyone's is different. but i think that some companies won't do that. not sure which ones.
yeah you can get an alignment done..it's not like they are doing an inspection or anything.
Old Jul 23, 2007 | 01:39 AM
I heard shops can get a $10,000 fine for letting a vehical leave without a cat. I'm wondering if that is only hardcore mechanic shops and places like Tires Plus are exempt.
Also I need my SRS reset. Could I go to Honda without a cat?
Old Jul 23, 2007 | 02:17 AM
NTCustoms's Avatar
have you tried the paperclip trick?
Old Jul 23, 2007 | 03:41 AM
hawaiiancb74's Avatar
Default Re: (NTCustoms)
they are fined if they do exhaust work and take your cat out .. then yeah. if they arnt workin on it that its not their problem ..
Old Jul 24, 2007 | 02:42 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NTCustoms &raquo;</TD></TR><TR><TD CLASS="quote">have you tried the paperclip trick?</TD></TR></TABLE>
I don't throw any codes if that's what that solves. So it won't matter to any shop?
Old Jul 24, 2007 | 09:33 AM
NTCustoms's Avatar
paperclip trick just resets the SRS. won't matter at a shop...at least in the US
Old Jul 25, 2007 | 02:43 AM
I'm not worried about a shop not letting me in for the SRS light. I want it fixed and want to know if I can go to the Honda dealer w/o a cat.
Old Jul 25, 2007 | 07:50 AM
black92DA's Avatar
Default Re: (WhiteOnRice)
yes u can go to a honda dealer w/o a cat
Old Jul 25, 2007 | 10:17 AM
NTCustoms's Avatar
why not try the paperclip trick? its simple. here's what you do:
unplug the yellow SRS plug in the interior fuse box. stick one end of the paperclip in 1 terminal, the other end in the other terminal. turn the key to the position II. it should beep 3 times, then the SRS light should go off. take out the paperclip and it'll come back on. put it back in, it should go off, then flash twice or so, and then stay off. remove the paperclip, remove the key, and replace the yellow SRS plug. test it out by putting the key in position II, after all the lights go on they should all go off again.
Old Jul 25, 2007 | 12:32 PM
Does that actually fix the SRS (will airbag go off if SRS light is off)? I had the same problem in my accord but didn't want to reset it myself because the wriet up said there is a chance that the airbags would go off. True?
Old Jul 25, 2007 | 03:11 PM
NTCustoms's Avatar
i did it and the airbags did not go off
Old Jul 26, 2007 | 12:20 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteOnRice &raquo;</TD></TR><TR><TD CLASS="quote">Does that actually fix the SRS (will airbag go off if SRS light is off)?</TD></TR></TABLE>
I'll probably just go to Honda. $60 is worth it. Airbags have saved my life once already.
Thanks for answering the cat question. I have put that off for 4 months trying to get stock exhaust.
ohhhmarkymarkEG6
Jul 18, 2006 09:23 PM
8krdline
Welding / Fabrication
Mar 2, 2005 01:58 PM
quietzone
38
Nov 9, 2004 03:40 PM
lsteggy
Apr 15, 2003 07:36 PM
Tommy_Gunns
May 31, 2002 02:19 PM
