90 Accord DX
I've had a heck of a time with getting the speedometer to work. The speedometer started working intermediately, the oem vss was replaced. Did not correct problem. Took the car to a shop where try replaced the vss, still did not fix the speedometer. The oem sensor was put back in, while waiting for a new vss to be ordered. The speedomter worked intermediately again. The 3rd replacement vss went into the car and no speedometer ?? What else could it be ? And is it a DIY fix?
after you try to change the same part 4 more times, you may want to step back, and look at something else. Check the wires going to the VSS. Check the connector itself, see if its making a good contact. Theres also the possibility that its a faulty cluster.
What ever the piece inside the tranny is that works with the vss could be bad. I had this problem with my Civic once, had to get a tranny...worked fine after that.
hand1222000
Jun 7, 2010 06:56 PM
HmgLauj69
Aug 4, 2005 02:29 PM
