Mileage not showing on cluster etc'
Is there a way to reset the cluster and/or what would cause the mileage etc to randomly stop showing up on the cluster? Where the mileage etc is always shown it just says trip-A
ap1 cluster'
it was working fine and displayed everything'
ap1 cluster'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr. Projekt »</TD></TR><TR><TD CLASS="quote">Hit the "Select" button til your odometer shows up?</TD></TR></TABLE>
Can it be that simple?
To the OP: If it says Trip A, then it's on the trip odo. It should go to Trip A, Trip B, then to the total odometer. If you have a newer S2000, another option will show Oil Life.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo »</TD></TR><TR><TD CLASS="quote">
To the OP: If it says Trip A, then it's on the trip odo. It should go to Trip A, Trip B, then to the total odometer. If you have a newer S2000, another option will show Oil Life.</TD></TR></TABLE>
if you remember to reset each oil change...
the select button just changes it from mph to kmh, the other button just changes it from trip a to trip b, then back to a etc'
cluster mileage does not show up', this is very odd'
also the cluster beeps upon inserting the key and priming the vehicle and cranking it over'.....
Modified by digital sol at 4:48 PM 7/23/2007
Modified by digital sol at 5:01 PM 7/23/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by digital sol »</TD></TR><TR><TD CLASS="quote">the select button just changes it from mph to kmh, the other button just changes it from trip a to trip b, then back to a etc'
also the cluster beeps upon inserting the key and priming the vehicle and cranking it over'.....</TD></TR></TABLE>
Sorry, I don't remember my AP1 cluster. The Select button selects between trips and oil life. If you hold it down, you change the mph to kph. The other button (Reset, I think) resets the trip counter.
The beep is normal. Most, if not all cars to that. It's the seat belt chime. Plug your seat belt in during the chime and see if it stops immediately.
The beep is normal. Most, if not all cars to that. It's the seat belt chime. Plug your seat belt in during the chime and see if it stops immediately. </TD></TR></TABLE>
alright yea you were right about the beeping issue, reason why i was new to me is because i didnt have the seat belt wiring connected before hand. Everything works perfect except it wont show mileage or how many miles are on the trip counter, it just gives me the option of changing the trip to a or b how-ever when i first insert the key the mileage icon and others light up for a temp second so i know there at least getting power properly and so fourth'
