Wrong spark plug wiring
Old Jul 22, 2007 | 01:29 PM
Neejay's Avatar
Default Wrong spark plug wiring
1997 Accord LX Non-vtec (F22B2)
After tons of research, I think I still have my spark plug wiring wrong. I forgot to do them one by one, and pulled them all off.
I've changed the spark plugs (NGK pre-gapped), spark plug wires, dist. cap, dist. rotor).
As of now, I have tried 3 different configuarations:
Engine = 4 3 2 1
3 (coil plug) 4
1 - 2
1 (coil plug) 3
2 - 4
2 (coil plug) 1
4 - 3
I also just noticed on both the older dist. cap and the new one, there's a circled A which Im assuming is marking for the #1 cylinder. I assumed that config #2 (above) was the right one from getting it from another accord-specific forum, but that's assuming the cylinders = 4 3 2 1 (looking into the engine bay from the front) and the firing order is 1 3 4 2.
Any help is greatly appreciated.
Old Jul 22, 2007 | 02:20 PM
JDM_DC4_Fanatic's Avatar
Default Re: Wrong spark plug wiring (Neejay)
the firing order is 1-3-4-2. The cylinders start from the timing belt 1 being the closest to the belt, 4 being closest to the dizzy. #1 cylinder lead on the cap is the one that on the 'top right' of the cap if you look at it from the passenger side fender.
Old Jul 22, 2007 | 02:33 PM
Neejay's Avatar
Thanks a ton man, I got it started!
justinCO
Jun 5, 2008 08:19 PM
redhondacivic
Mar 29, 2006 04:09 PM
civicproblems
Jan 9, 2005 03:03 PM
