jdm b16a swap ?s
Old Jul 22, 2007 | 12:08 PM
EGprojectkdkd's Avatar
Default jdm b16a swap ?s
so i went on hmotorsonline and found a b16a for 1750. it says it comes with everything but axels shiftlinkage and mounts. would i need anything else to swap this in an 95 eg hatch
Old Jul 22, 2007 | 12:19 PM
ekb16's Avatar
if u already have mounts, axles, shiftlinkage then that should be pretty much all you need..if u dont have those then look for a complete changeover swap...u can find shiftlinkage, axles, and mounts in the classifides section for cheap if u search around
Old Jul 22, 2007 | 12:22 PM
Boosted4life's Avatar
Default Re: jdm b16a swap ?s (EGprojectkdkd)
beside shiftlinkage, mounts, and axles. Make sure u have vtec ecu, wire vtec. Have a tranny too.
Old Jul 22, 2007 | 12:26 PM
egsleepercivic's Avatar
timing belt, tensioner, water pump, axles, mounts, shift linkage, throttle cable(optional). I reccomend just getting the complete swap.
gl, I got the same swap and it was in excellent condition and still is 90k later
Old Jul 22, 2007 | 01:02 PM
forcefedferio's Avatar
Default Re: (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">timing belt, tensioner, water pump, axles, mounts, shift linkage, throttle cable(optional). I reccomend just getting the complete swap.
gl, I got the same swap and it was in excellent condition and still is 90k later </TD></TR></TABLE>
for the headache factor above all else the complete swap option is the way to go
Old Jul 23, 2007 | 11:07 AM
ok were is some good places to get a complete swap
Old Jul 23, 2007 | 11:10 AM
95ProjectEJ1's Avatar
Default Re: (EGprojectkdkd)
Hmotorsonline is a good place from what I have heard. There may be shops in your area that are just as good, that way you can cut down on shipping costs and make the deal a lil more sweet for you
Old Jul 23, 2007 | 11:11 AM
deadline's Avatar
use ls mounts and brackets
Old Jul 23, 2007 | 11:29 AM
hmo motors is the best in my opinion, if you can get it shipped to a business its cheaper. but if you want someone closer try Import Auto Salvage, they are in Marion, NC ask for Larry Jr. Just to let you know I had my motor shipped to FL from HMO and it was still cheaper than IAS, but both companies have a great rep. call them up and see what works out better for you
gl
abs0Lut
Oct 20, 2011 06:54 AM
crx4ever
Jun 12, 2006 09:45 PM
gsrhb7
Jun 1, 2004 09:24 AM
TypeR0207
Aug 9, 2001 02:22 PM
