EF9Robert's new parts installed :-)
Old Jul 22, 2007 | 10:43 AM
ef9robert's Avatar
Default EF9Robert's new parts installed :-)
UPDATE!!! Paint almost done!!
Yesterday did some work on the ride.
Installed the following items:
EF9 Hatch (bronze glass) with EF9 Rear spoiler
J's Racing hatch spoiler
Password JDM front lip
EF9 front seats
GAB Rear strut bar
JDM Rear bumper spoiler pieces
Installation for the rear ef hatch, was sorta simple. Thanks to my trusty wood stick i was able to prop up the hatch and remove the 4 bolts that hold the hatch to the hinges. I couldn't figure out how to take the wiring off so i ended up cutting the harness
Installed the jdm hatch using my trust stick again and vola, jdm hatch installed. I didn't have my voltage meter here @ home so I will have to wait till i wire up the third brake light.
For the J's racing lip, I sanding it a little and rattle canned it with some black primer, slid it over the jdm hatch spoiler and screw it with some 1/4" screws.
Password JDM was sorta a bitch to put in by myself, good thing i had some clamps so i used them to line it up, put 2 screws on each side, then 2 in the middle, also did a tie strap on the bottom.
EF9 front seats, were a snap, after getting some help from my new homie Jose. Did a pan swap. So you just take the bottoms off the usdm seats and remove the cushions.
Once that is done you do the same with the jdm seats, then use the usdm pans and the jdm cushions and bam you are done. You do lose some functional options but i can deal with it.
Gab strut bar fairly simple and straight forward. Removed the rear strut interior caps, loosen one side of the bar using allen and 17mm open wrench. Fitted one side and then the other, tighten it up and done.
JDM rear bumper lower spoiler pieces. Most of the holes on the spoiler and bumper were trashed. So i just screwed it into the bumper and was done with it.
Hope this helps.
Thanks.
Modified by ef9robert at 2:46 PM 2/19/2008
Old Jul 22, 2007 | 11:52 AM
brokenef8's Avatar
Default Re: EF9Robert's new parts installed :-) (ef9robert)
Hey Rob its James, the Gold EF with the Recaro! Looking Good man! Saw you selling your parts and was wonder WTF was going on!
Old Jul 22, 2007 | 12:54 PM
abnaasefmb's Avatar
where did you get that "civic" sticker? i need one
Old Jul 22, 2007 | 01:57 PM
HatchMo's Avatar
it comes on the jdm garnish. Looks sick! How far off is the key hole from the key mechanism?
Old Jul 22, 2007 | 02:24 PM
ef9robert's Avatar
Default Re: EF9Robert's new parts installed :-) (brokenef8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">Hey Rob its James, the Gold EF with the Recaro! Looking Good man! Saw you selling your parts and was wonder WTF was going on!</TD></TR></TABLE>
Wassup James!!! EF has been on hold since other things have been taking my time. Going at her full time now!!
Hit me up in PM whenever u want to hang, let me know!!
Peace.
Old Jul 22, 2007 | 02:30 PM
ef9robert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchMo &raquo;</TD></TR><TR><TD CLASS="quote">it comes on the jdm garnish. Looks sick! How far off is the key hole from the key mechanism?</TD></TR></TABLE>
Its about a inch and half away from the original spot.
Old Jul 22, 2007 | 04:27 PM
Old Renegade's Avatar
LOOKS NICE BUT LOOSE THE SPOILER
Old Jul 22, 2007 | 04:31 PM
STREETWERKZ's Avatar
wow.
add some tech on how you did the install or take this thread to appearance/cosmetic.
Old Jul 22, 2007 | 04:37 PM
EFSedan#6's Avatar
How does the J's spoiler fit? I was told by a friend that it has to go on top of the factory SI spoiler. True??
Also, the rear lip, do the non-USDM sedans have something like that?? I love the look of your rear bumper lip pieces.
Old Jul 22, 2007 | 06:23 PM
KillSwitch's Avatar
Default Re: (Blanket-Jackson y0)
that wing is pretty ******* ugly
Old Jul 22, 2007 | 06:52 PM
MOE@Hyper16Valve's Avatar
Default Re: (KillSwitch)
DAMN gotta love the the theme of the car GOOD luck with the build...
DAMN some hard words on here about the parts on this car, would love to see what there cars look like ...
ROBERT see you NISEI week car show...
MOE@HYPER16VALVE...
Old Jul 22, 2007 | 06:57 PM
Default Re: (MOE@Hyper16Valve)
the tech part his civic is a 90-91 and i think the seats he has are 88-89 so how did you get them to fit???
Also the J's racing wing is a slip over wing that attaches to a JDM sir wing can be taken on and off at will depending how the wing is mounted...
Old Jul 22, 2007 | 07:07 PM
KillSwitch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MOE@Hyper16Valve &raquo;</TD></TR><TR><TD CLASS="quote">the tech part his civic is a 90-91 and i think the seats he has are 88-89 so how did you get them to fit???
im pretty sure it's the op that has to come up with the tech in the ******* thread not YOU!
EDIT: another tech part would be like how did you jack your car up and put your wheels on? lol h-t is goin down the drain...
Old Jul 22, 2007 | 07:09 PM
ef9robert's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blanket-Jackson y0 &raquo;</TD></TR><TR><TD CLASS="quote">How does the J's spoiler fit? I was told by a friend that it has to go on top of the factory SI spoiler. True??
Also, the rear lip, do the non-USDM sedans have something like that?? I love the look of your rear bumper lip pieces.</TD></TR></TABLE>
J's spoiler slips over the jdm sir spoiler. DOES NOT FIT USDM spoiler.
Rear bumper is a JDM spec bumper with no crash beam. Not sure if the usdm has a similar lip to fit, i am sure you can get a JDM lip and fit it on the usdm bumper.
Old Jul 22, 2007 | 07:11 PM
ef9robert's Avatar
moe, can you get me a replacement dual carb sticker for my hatch window? the one on it is in some bad *** shape.
Thanks.
Old Jul 22, 2007 | 07:31 PM
Theres some for ya lol ... think i told you to change the seat pans LOL...
ROBERT good ****...
Old Jul 22, 2007 | 08:08 PM
ef9robert's Avatar
Yup yup!! Have a set of seat brackets for sale :-)
Old Jul 22, 2007 | 08:16 PM
SheerEffort's Avatar
Looks Nice Not to much on the Spoiler But other then Thats Looks Great
Old Jul 22, 2007 | 08:41 PM
ef9robert's Avatar
Thanks, still debating on what color to paint her.
Old Jul 22, 2007 | 09:46 PM
Chewy Built !'s Avatar
Default Re: (ef9robert)
car looks hard bro! i just finished installing my j's racing wing today. We are almost twins, just that your car has more goodies, lol.
BTW, let me know about the taillights
Old Jul 23, 2007 | 04:14 AM
ef9robert's Avatar
Default Re: (Chewy Built !)
Mos def, you got first dibs, going to dig them out of the garage tonight.
Old Jul 23, 2007 | 06:09 AM
ef92b's Avatar
those wheels looks so sexy
Old Jul 23, 2007 | 06:45 AM
ef9robert's Avatar
Default Re: EF9Robert's new parts installed :-) (ef92b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ef92b &raquo;</TD></TR><TR><TD CLASS="quote">those wheels looks so sexy </TD></TR></TABLE>
Thanks, been debating if i want keep them or move on to something new.
Old Jul 23, 2007 | 08:12 AM
subgeniusdude's Avatar
Looking good man,props for doing up an OG EF old skool style!I like the black with bronze wheels!
Old Jul 23, 2007 | 08:53 AM
Suck my DX's Avatar
that wing is ******* GAY
