1997 civic ex start problem
Old Jul 22, 2007 | 06:13 AM
matt69vdub's Avatar
Default 1997 civic ex start problem
Hey guys newb here. I started my car yesterday and it idled rough like a cylinder was missing then it died. I popped the hood and my #4 spark plug wire came off the distributor cap. I plugged it back in and now it wont start.
I tested the wire and it read 1.3k ohms, so its still good.
When it fell off could it have arced and messed up the distributor cap in some way?
Thanks for replies.
Matt
Old Jul 22, 2007 | 07:49 AM
matt69vdub's Avatar
Default Re: 1997 civic ex start problem (matt69vdub)
Ok I replaced the distributor cap and it still wont start. Is there a fuse I could check that goes between the ignition?
I smell fuel when I crank it over so its obviously not fuel related.
Old Jul 22, 2007 | 08:00 AM
h2392si's Avatar
When was the last time you did a tune up? Like the wires, plugs, rotor cap, etc. Check your fuse box and fuses under your steering column.
Old Jul 22, 2007 | 08:21 AM
Ahmad ibn-Fadlan's Avatar
So I assume the starter is turning it over.
Assuming that, air/fuel/spark makes fire go.
your getting air, you smell fuel, so spark
pull a plug wire and have someone turn it over and get the plug wire to arch on the engine.
Plus how is it not starting? just keep turning over?? is it trying to start? dieing ? what?
Old Jul 22, 2007 | 04:47 PM
matt69vdub's Avatar
Hey guys sorry. I should have posted more info.
Yes the starter turns it over, but it dosent start, the plugs smell like fuel, but they arent getting any spark. Its an automatic if that helps.
I put new plugs and wires on it 2 weeks ago(probably why the # 4 wire came off the distributor).
But yeah, its not getting any spark. How do I check the coil?
Which fuses would one check for no spark?
Old Jul 22, 2007 | 06:22 PM
matt69vdub's Avatar
Ok I'm gonna check the coil ohms tommorrow.
Old Jul 23, 2007 | 08:35 AM
matt69vdub's Avatar
Well I checked the coil and the ohms read good. Then I tried testing the icv like in the writeup and made it to step 5 then was confused so I just went down and bought a new distributor slapped it on and it fired right up.
So it was the distributor.
SVOHK
Jun 18, 2015 08:46 PM
jg545
Nov 6, 2012 03:14 AM
PapaMoose
27
Nov 19, 2011 03:00 PM
ne0nblakk
15
Mar 14, 2011 11:40 AM
PerfectTechs
Mar 23, 2008 10:15 AM
