obd1 jdm gsr swap into obd2 ls teg help
I have a gsr motor that was converted to obd2, my ls integra is a 96 obd2. my question is, what will i need to swap it right up to my car, can i reuse my LS harness? DO i need something to connect my vtec, iab, and knock sensor? my ecu is a p30 obd1 but was changed to obd2 with harness converter and its also chipped. it came with the swap when i got it off with someone. should i get a p72 usdm or jdm obd1 or obd2? im confused.
For any easy pnp install you can buy a rywire or hasport (EGDX-GSR) ls to gsr subharness and use the ls engine wiring harness. Hasport is more expensive but higher quality.
They both have wiring for vtec solenoid, vtec oil pressure, iab, and knock.
With the ls harness you'll have to extend the wiring for iat sensor and evap purge solenoid.
For the ecu, an obd1 p72 is probably easiest. Don't know if u can use existing p30. Don't know enough about chipping.
you just need to decide what way you wanna go and do it... you also wanna think about emmissions in your state....are their emmisions, the only reason i say that is a obd2 car with an obd1 computer will not pass emmisions because they cannot plug a scan tool into the obd1 style ecu... let me know if you need more info....hope this helps
xtreme26
Jul 26, 2008 12:34 AM
