I want to swap a Dohc ZC in to my 95 eg VX, wut parts do i need?
Old Jul 22, 2007 | 12:01 AM
DeathSquad's Avatar
Default I want to swap a Dohc ZC in to my 95 eg VX, wut parts do i need?
i have a dohc Zc motor. i think its a jdm motor. i need to know everything about swaping it in. could really use the help and advices. thanks.
Old Jul 22, 2007 | 12:27 AM
inspireAZN's Avatar
Zc? z6?
dohc? sohc?
Old Jul 22, 2007 | 12:39 AM
DeathSquad's Avatar
Default Re: (inspireAZN)
its a jdm dohc zc motor.
Old Jul 22, 2007 | 12:41 AM
24TEN's Avatar
PHANTOM MENACE
He said DOHC ZC, D16Z6 is SOHC so I'm pretty sure it's safe to assume he meant what he said.
As far as I know the DOHC ZC did come in an OBD1 variant. Are you sure you want to go through with this swap? It's not legal for your car. I have one myself and had to find out the hard way that I can't get a BAR label. If smog is not an issue, then shoot go for it. Do you know what year/OBD your motor is?
Old Jul 22, 2007 | 12:46 AM
DeathSquad's Avatar
Default Re: (24TEN)
my motor right now is an OBD1. and yea im sure i want to do it becuz the first owner of my car freaken ran into a ditch. and the vx motor is filled with mud and water. so i have a zc motor just sitting there so i might as will do it.
Old Jul 22, 2007 | 12:48 AM
DeathSquad's Avatar
Default Re: (24TEN)
oh yea, do i need to do anything to prep for the swap?
Old Jul 22, 2007 | 12:51 AM
24TEN's Avatar
PHANTOM MENACE
I haven't dealt with an OBD1 version, but under assumption, the motor should still bolt up the same in the engine bay (still bolts up as a D-Series) with most of the same plugs. For my car (91 Civic) it's the same thing as a basic Si motor with the only wiring difference being a cam angle sensor on the exhaust cam(SOHC Si distributor has the sensor built into it already, DOHC ZC has it as a seperate sensor). That's as far as my knowledge goes. Anyone else have info to share for running it in OBD1 form?
Old Jul 26, 2007 | 08:09 AM
quintb2000's Avatar
Default Re: (24TEN)
just put one in my 93 dx and it bolted up perfect.....use your stock harness.....i have a prob with my dizzy though i think.....
Civic Hx-T
34
Jun 17, 2016 09:29 PM
muddmonky
Jul 12, 2012 07:18 PM
Potential2nr
Jan 6, 2012 03:11 AM
tegracer19
Oct 14, 2007 04:33 PM
FastAzzDA
Oct 23, 2006 07:57 AM
